Johnathan mod help
Old Jan 9, 2011 | 09:19 AM
CivicxTree754's Avatar
Photogenic
Loved
Default Johnathan mod help
Heres the info I found. Iam going to be doing this but need to know what years acura legend brake calipers are applicable to this Mod.
Heres the write up:
Jonathan Mod
Well guys...you'll be glad to hear that it isn't necessary to hunt down those scarce EX knuckles to upgrade to 10.2" brakes. This bolts onto the non-EX 88-91 Civic/CRX knuckles!
Want to know how it's done?
Read on below to discover the beauty of the Jonathan Mod
Parts list:
'91 Civic EX Brake rotors...same as 92-95 Civic Sedan rotors ($14.99 each at Pep Boys; probably cheaper at AutoZone)
Accord Wagon Brake Calipers (will be stamped 17CL15VN; ~$50 rebuilt at Pep Boys). These are the exact same calipers as the ITR, Legend, Prelude VTEC etc. Great stopping power!
Accord Wagon, Prelude VTEC (etc) Brake Caliper mount stamped 25T (a 23T bracket exists, but I can't promise you it will work). This is what came stock on the Accord Wagon.
1/8" wheel spacer OR grind ~1/8th" (2.5-3mm) off of the caliper mounting bracket. If you are familiar with the 11" brake upgrade, this is the same modification necessary.
Im asking because i have a acura legend front clip and at least 4 or 5 claipers from off the legend at my buddies shop i could use for this. Someone also said something about a VW rotor, integra calipers, and FB bracket kit but i couldnt find any prices on the bracket kit. Im more interested on using the legend calipers cause I have them.
Edit: I found the FB bracket kit and im not paying 300$ + for that. I have parts already all i may need to do is get rotors. Just need to make sure i have the right rotors.
Old Jan 9, 2011 | 09:48 AM
FSRslug's Avatar
Default Re: Johnathan mod help
I "think" it is 91-95. I am running 94 or 95 calipers.
Why do you want to do this though?
I have to grind the brake pads down so they don't rub the rotor hats. It annoying, but it works. I probably could have gotten the same stopping power by running a little better pads with the stock brakes and getting stickier tires.
Old Jan 9, 2011 | 10:21 AM
Photogenic
Loved
PLanning on running autox when my car is complete but better stopping power isnt bad especially when you already have most of the parts. And what do u mean by grinding down the pads to not rub the rotor hats?
Old Jan 9, 2011 | 08:29 PM
1990hondacrx's Avatar
I have the Calipers to do this swap to mine but have not started it yet with the legend calipers the biggest difference everyone has told me about the swap is that since you have such a bigger pad to the sweeping pass you get a killer stopping power I'm going to run ebc pads on mine when I do it with a good set of rotor blanks from a 93 teg...
please before you do the swap do some test measure some place outa town or something where you can do 60mph and measure your breaking distance before and after and let us know im really interested in the results from this swap, i will be moving up from HF rotors to this so should be night and day for me
Old Jan 9, 2011 | 08:32 PM
Photogenic
Loved
Will do...im not gonna use teg rotors im gonna use the accord rotors it specifies. also i found the info....i beileve its all legend calipers 91 to 96 and also RL calipers too. I looked up alot of info but wont know for sure untill i get to the shop to look at the calipers.
Old Jan 9, 2011 | 08:35 PM
Blaze45's Avatar
Brrraaaap!
So you can use the these same calipers on 92-95 civics as well? Is there more pad that is available or just more piston pressing on the pad?
Jonathan_ED3
451
Nov 30, 2024 01:35 PM
EFsideways
20
Dec 27, 2007 07:38 AM
rev_it
Dec 23, 2006 02:16 PM
CRX Toad
13
Jan 19, 2005 08:06 AM
MJ23FE
Nov 19, 2002 09:12 AM
