ef9 brake problems
for some reason when im in the freeway my front right hand brake starts brakeing with out me pressing on the pedal.when i go to brake that wheel shakes too crazy.please help
sounds like that caliper is stuck or something else is stuck.
The shaking may be due to excessive heat buildup due to the sticking.
Flush the braking system with new fluid, bleed the system and make sure you are getting similar fluid output from each caliper and the action is smooth.
Turning your rotors will make them heat faster due to being thinner.
As for rebuilding your calipers I would say if you have to ask it is probably not something you should be doing and would suggest you buy good working ones or get rebuilt from the parts-store.
Try what was suggested first with the bleeding and new fluid and then get back to us for more things to try if that does not work.
Charlie Moua
Suspension & Brakes
Feb 18, 2012 04:46 AM
Surewin
Mar 16, 2005 11:32 AM
