wats a good fuel adjustment for field vtec controller?with mods
got a sohc vtec motor with 3 basic bolts on, frp, field controller and a spoon chip ecu. wat is the best setting fuel. should i mostly lean it out for every rpm. or the best thing to do it dyno. thanks in advance
get it on the dyno. that is the only thing that should be done. find out what the air/fuel ratio is currently and tune it accordingly. don't touch the fuel pressure, stock is sufficient for bolt ons, just get it on the dyno to tune for a good air fuel ratio of about 14 parts air to 1 part fuel.
guess i have to dyno it then. wat is the stock fuel pressure for a d16z6. is it 30psi or more.
JDM_EK4_Coupe
May 1, 2007 01:25 AM
