EGR Question and vacuum questions?? need help
Old Jan 9, 2011 | 07:41 AM
brian8702's Avatar
Default EGR Question and vacuum questions?? need help
ok got a 92 honda accord lx with a 01 h22a swapped.
right now im trying to get it fine tuned to where it runs good
im using a stock f22 ecu for now only til i order a p13.
from advice from guys on here with what to do with the black box and the black canister.
i've removed both. but what do i do now with the egr valve?
block if off? where should i stick the vacumm hose to?
I'm rewiring my map sensor after i post this
I've plugged up all the inlets on the intake
and the rpms dropped from 2500 to about 1100
sometimes when i drive if i apply the clutch or stop
the oil light will come on and the engine will turn off.
The line that comes from the return to the gas tank i rerouted to the intake to where the line would come from the black canister.
I really need some help. i'm moving next week to arizona from ohio and i wanna make sure the car is running good. so i dont run into problems and have the best mileage
Old Jan 9, 2011 | 11:43 PM
holmesnmanny's Avatar
Default Re: EGR Question and vacuum questions?? need help
Seriously, what in the hell are you doing? Who told you to do all that?
Old Jan 10, 2011 | 10:34 AM
brian8702's Avatar
some of the guys here and off of cb7tuner dot com
i put all the stuff back on including the black box and the black canister.
i wired up the map sensor using the accord map but now im getting a cel 5
92cb7sk8er
Oct 7, 2010 03:01 PM
brian8702
Aug 24, 2010 12:02 AM
maziospzza
25
Apr 15, 2010 06:58 AM
oldcivicguy
Aug 3, 2009 03:42 PM
DC5ftmfw
Mar 7, 2007 05:27 PM
