h22 porting im tb
Old Jan 9, 2011 | 03:49 AM
accordmatt's Avatar
Default h22 porting im tb
ok l have a h22 and sk2 68mm tb lm porting the manifold to portmatch tb. sk2 eliminates coolant lines but passage on stock manifold for map sensor to read from tb is bored out do l need to cut a divit for that or should be ok?
Old Jan 9, 2011 | 03:55 PM
nus_dogg's Avatar
Default Re: h22 porting im tb
The coolant lines are there for the Fast Thermal Idle Valve(FITV) to help control idle at cold start up. Skunk2 TB eliminates that and your car will idle alot lower with the S2 TB cause there's no more FITV when the engine is running cold.
Just get some coolant hoses and re-loop the coolant back into the passages. I believe thats what I did with mine. I forgot.
Old Jan 9, 2011 | 03:57 PM
accordmatt's Avatar
thxs yea was talking to guy doing swap with me and we figured it out and ur totally right cool deal
Old Jan 9, 2011 | 04:01 PM
nus_dogg's Avatar
What size TB do you have? Mine's a 68mm TB with my upper plenum portmatched by rosko. Made a difference too.
I recommend you buy Rosko's TB Thermal Gasket. If fits nicely too @ www.roskoracing.com. Email him.
Old Jan 9, 2011 | 04:05 PM
accordmatt's Avatar
68mm like u got on here for 100 bucks like new. l got gasket with it and portmatched myself. lm at last bit of swap so l kinda gave up for now l have like a 1/8 left to grind to perfectly match but whats that gonna hurt. when l do camshafts and gears and upgrade fuel pump ill finish but it will do for now
Old Jan 9, 2011 | 04:13 PM
nus_dogg's Avatar
Thats cool.
Old Jan 9, 2011 | 04:51 PM
accordmatt's Avatar
now what would u suggest? running my short ram or just filter bolted on tb? for now? it is cold so l dont think my cold air is nessasary
Old Jan 9, 2011 | 05:33 PM
nus_dogg's Avatar
Short Ram will do just fine. Go 3" intake piping; thats what I have now. You can get them off ebay and run a quality filter. Or you can do the filter clamp onto the TB and I forgot if you'll gain lowend or what but yeah.
Old Jan 10, 2011 | 05:54 PM
jarol220's Avatar
How can you just bypass the Iac valve do you have to change the ecu or tune it out for that?
djteggy99
Jun 23, 2010 09:13 AM
defythemall
13
Jan 21, 2009 08:32 PM
exratedaccord93
Aug 14, 2006 12:19 PM
DriveSlowHomie
Dec 17, 2005 06:02 AM
Sinner
May 29, 2003 10:41 AM
