LIMP MODE!!!!!obd0 B18
Old Jan 9, 2011 | 01:20 AM
fugett's Avatar
Default LIMP MODE!!!!!obd0 B18
Trowing code 16.(injectors)
my injectors are fine. what else could it be?
wrong fuel filter?(still using dseries one)
finally got my car roling and now this...any tips?
Old Jan 9, 2011 | 01:23 AM
d0wnShiFt's Avatar
Default Re: LIMP MODE!!!!!obd0 B18
b series swap into what car??
Old Jan 9, 2011 | 09:12 AM
tonythetuner®'s Avatar
Ya man is the car a si.. or a dpfi swaped to mpfi swap??.... could be the wiring if it was converted to mpfi. And no the d series fuel filter will not cause that unless it is really cloged up
Old Jan 9, 2011 | 01:44 PM
fugett's Avatar
it was the 4spd model.and i did do the dpfi to mpfi conversion.
now cylinder 1 on the exhaust manifold is not getting as hot as the rest.
Old Jan 9, 2011 | 02:03 PM
Dobble check your wiring hears a link. http://hondaswap.com/swap-articles/d...writeup-49557/
Old Jan 9, 2011 | 02:43 PM
Laserjock's Avatar
See my post here re: injector diagnosis:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/gasoline-leaking-1-exuast-port-zc-dohc-2880349/
AH419
Jul 13, 2012 09:57 AM
sIcKvIc
Mar 23, 2005 02:48 PM
civicnightmare
10
Aug 16, 2004 12:05 PM
itsmebeaner1987
Jul 29, 2004 10:30 PM
basemies
Jul 18, 2002 06:38 AM
