EK brake upgrade
Old Jan 8, 2011 | 05:52 PM
thapimpfromchi's Avatar
Default EK brake upgrade
are there any simple or direct bolt on brake upgrades that aren't too expensive? maybe something from another vehicle.. or a super cheap big brake upgrade? Im boosting my car over the winter and I want to improve my braking too. Any ideas and suggestions would be nice. Thanks.
Old Jan 8, 2011 | 06:01 PM
titosek4's Avatar
Default Re: EK brake upgrade
I did a 01' gsr front and rear brake upgrade. Made a big diff for me
Old Jan 8, 2011 | 06:13 PM
98civdx's Avatar
Master Detailer
We need to know what exact model you have. EK doesn't help.
Old Jan 8, 2011 | 06:16 PM
titosek4's Avatar
true but when I hear EK I only ever think of 96'-00' hatchback so I assume it's a hathback
Old Jan 8, 2011 | 06:34 PM
98 dx 2d coupe. but its got a full si (em1) brake upgrade currently. Looking for something a little better. i was thinking about gsr. i heard those are pretty beefy.
Old Jan 8, 2011 | 06:37 PM
94EG8's Avatar
Seagull Management
integra front calipers and prop valve from a '98 - '01 integra RS
Old Jan 8, 2011 | 06:44 PM
Chef Andre's Avatar
HT's TOP CHEF
I have some ITR front calipers and redrilled prelude rotors fo sale. Prelude rotors are 11.1 as opposed to stock Si's which are 10.2.
Old Jan 8, 2011 | 07:38 PM
98civdx's Avatar
Master Detailer
meh, not good to assume.
Could have been anything from a 96 dx coupe/hatch to 99 si.
Chef Andre's idea has my vote. My friend's car will freaking put your head in the dash if he slamms on the brakes. (98 ITR)
That or, Integra calipers, which have a bigger piston, and will likely be cheeper to get then ITR calipers.
Old Jan 8, 2011 | 08:58 PM
chef: will those calipers bolt up to the brackets i have on my car, or would i need different brackets too? and would those bolt right up?
Old Jan 8, 2011 | 09:01 PM
just curious... what difference would it have made?
Old Jan 8, 2011 | 10:34 PM
Deetz's Avatar
Crazy Honda Guy
just a heads up about itr calipers......
- they are the same part number as 97-01 crv
- acura vigor
- prelude, forgot which model though
there are many used sources to locate a cheap upgrade
The other good option is to check out "Fastbrakes", great company, great prices!!!
Old Jan 9, 2011 | 07:20 AM
94EG8's Avatar
Seagull Management
The knuckles are different, integra calipers are a straight bolt on for EX/Si models. Otherwise you need to swap knuckles as well.
Old Jan 9, 2011 | 07:39 AM
MonkeyMagic's Avatar
OP, what kind of pads and rotors are you running?
side note: who is that guy on here that does all the oem brake upgrades.
i remember he had a thread about 5 lugging an ef.. then went on to make threads of instructions using the prelude rotors and all kinds of good stuff??
i want to say he had the word black in his screen name.. avatar was an obscure picture of the brakes on his ef. iirc
Old Jan 9, 2011 | 08:58 AM
unfortunately my car is currently rocking some duralast brake pads (autozone) and i have no idea what brand the rotors are. i got the car this way. i was thinking ebc all around but i want bigger calipers and rotors for better stopping power.
Old Jan 9, 2011 | 09:25 AM
sk8shorty012's Avatar
I would keep your current setup.
Make sure you have the 40/40 proportioning valve, the correct master cylinder and brake booster for the setup (since you orig. had a dx) and then install a good set of pads.
Should be more than enough stopping power, I know plently of guys that track with that setup. Infact, I had ITR brakes ALL the way around and actually downgraded to the complete EM1 setup because I liked it better.
Remember that brake upgrades induce unsprung weight and those ITR calipers / rotors are VERY heavy respectively.
Old Jan 9, 2011 | 10:25 AM
94EG8's Avatar
Seagull Management
CX, DX hatch/coupe, HX and Si all had the same prop valve. The only ones that are different are the EXs and DX/LX sedans.
Old Jan 9, 2011 | 10:44 AM
98civdx's Avatar
Master Detailer
Knuckle are different, You have 9.6'' brakes were as the Ex/SI have 10.3'' in front and the SI has rear disk.
Old Jan 9, 2011 | 10:52 AM
Right. That was more centered around the master cylinder. In fact, he already has the correct prop valve & brake booster. My recommendation would be just a larger master cylinder (7/8 from EX/Si) and then a good set of pads the next time he needs them.
Old Jan 9, 2011 | 10:58 AM
98civdx's Avatar
Master Detailer
Hawk hps or hp pads and some brembo blanks would be a great setup, also I would flush the brake fuild. depending on how it looks.
Old Jan 9, 2011 | 11:52 AM
no no no.. you got it all wrong. your gsr brakes are fine for anything you'll ever need to stop for. and any big brake kit you are looking at is more likely to increase stopping distance.
do this:
after which get a good set of tires. a good sticky set of tires is the best upgrade you can get. after all, they are the only part of the car touching the ground.. so the more friction you can generate there, the better your brakes will shine.
Old Jan 9, 2011 | 12:03 PM
98civdx's Avatar
Master Detailer
correct, I should have stated that.
The best brakes in the world wont do crap without a good set of tires.
Old Jan 10, 2011 | 01:52 PM
I have good tires. Running general tire UHP. Thanks for the info guys.
Jon777
Suspension & Brakes
May 26, 2011 02:00 PM
Malakai
Sep 11, 2006 06:25 PM
Ashnice
Jun 30, 2004 02:59 PM
SuperMan19
Mar 19, 2003 09:18 PM
