case swap q's
I have a 1999 gsr usdm transmission and where the pass side mount bolts up snapped. I also have a 1995 b18b usdm transmission. Can i use the 1995 b18b case on the 1999 gsr transmission without modification?
It will fit. Yes. It is the same case. Without modification? Doubtful.The bearing preloads for the differential and mainshaft will most likely be off and will need re-shimmed.
stripes777
Mar 8, 2004 09:37 PM
mskibbz-T
Nov 13, 2003 08:01 PM
