winter clean out sale(parts cars turbos)
all the parts need a new home because i dont need them. but plz make a offers on somethign you want but dont low ball shippin will be added to any items paypal will be best but pickup it ok as well.
Ihi warenerishi turbo t3 flang no play with down pipe flang 110$
sohc budget turbo set up 225$ Hf manifold,BMC race adapter, Evo3 turbo,02 housing,and oil fittins.
Twin turbo set up off a supra one turbo looks like it MIGHT be a replacement othr turbo has a chipped fin both working on stock car befor removed for big single 200$
D16y8 head with vlavecover and vtec solnoid 100$
d16y5 head with valvecover and vtec solnoid 100$
D15b7 head no cam all working cam was used for a core 50$
D16a6 intake set up all accys on it from a 1991 crx si 50$
d15b6 HF intake set up all accys on it 50$
4 sohc 16v non vtec valvecovers 20 each$
wrinkle red sohc Vtec valve cover 50$
spray bomb gold sohc vtec valvcover 20$
b20 valvecover needs repaint 30$
crx 5 speed HF tranny 150$
crx shift linkage 25$
crx HF clutch 89 only 70k miles 25$
crx ALT HF with 70k miles 40$
2x driver side crx mirros 25 each$
one crx head light (not sure side have to look again ) 25$
crx SI dizzy 75$
crx DX dizzy x3 50$ each
obd 0 LS dizzy i think 50$
HF crx crank pulley 20$
LS crank pulley x2 25$
crx tail lights outter only 30$
hood latch cable EF 20$
T bar for crx 20$
front rad support cut from CRX 75$
90 si rear bumper crx 50$ red
B series ALT newer with bracket 70$
pm5 ecu 20$
pm6 ecu 30$
p06 auto 30$
p06 stick 40$
pm8 ecu 20$
JDM parking pole with switch and pig taile works with green light 125$
2000 integra typeR need to be finished 43k miles clean orig title with d16z6 swap 6700$
Y8 water pump used x2 10$
LS waterpump used 10$
GSR water pump 22t used 15$
factory EF alloy mesh wheels 13'' 100$
EG antenna block off with gasket never used 20$
sohc starters x2 30$
bran new ebay EG blinker light clear clean never used 20$
brand new EK coupe side skirts aftermarket 50$
brand new pistion rings 75.5mm sohc 50$
2005 kfx 400 with mods minty and fast 2700$$$$$$$$
2004 crf 50 very modded street legal with light and red barron frame and the list is long 140cc 2000$$$$
1985 atc 70 with lifan 125cc motor new tires new seat cover needs new fuel lines.700$
misc parts left from 89 crx HF with 70k miles
crx SI dizzy 75$
T bar for crx 20$
pm5 ecu 20$
pm6 ecu 30$
p06 auto 30$
p06 stick 40$
pm8 ecu 20$
youngwon22
Sep 10, 2003 08:10 PM
