new to hondas
Old Jan 7, 2011 | 03:35 PM
slobaltTVS's Avatar
Default new to hondas
just got a 94 prelude, but it has an f22a1 what are some ways i can convert to maybe a b series or an h22a, or atleast is it possible to switch the head to a dohc vtec? also with it being a 94 i dont have the tail lights i would like to have. how would you go about converting to the more slim and longer lights? if possible, thank you
Old Jan 7, 2011 | 03:36 PM
serjey15's Avatar
Default Re: new to hondas
B series will not fit into a honda prelude.
Buy an obd1 h22a for 900 bucks and drop it in.
taillights you can not convert unless you do a bunch of welding and bondoing and in the end it will make your car look worse
Old Jan 7, 2011 | 03:38 PM
slobaltTVS's Avatar
any ideas where to find an obd1 and an h22a for around this price?
Old Jan 7, 2011 | 03:58 PM
minilogoguy18's Avatar
You never want to cheap out on buying an engine, buy from a reputable dealer even if the price is a little more than most places.
http://hmotorsonline.com/
Old Jan 7, 2011 | 04:51 PM
serjey15's Avatar
yeah i guess. i mean the chapest iv sean is 800. find something for 1000
Old Jan 7, 2011 | 09:38 PM
nus_dogg's Avatar
I got my H-Series for only $900.00 shipped from Japanese Star Motor located in Albany, NY. Go H23A VTEC blue top if you can; more torque baby!
Old Jan 7, 2011 | 10:00 PM
X01Michael's Avatar
welcome to the life of **** breaking and constant endless money ahah. buy a JDM H22a and put it in. no question about it. if you need help with anything you can PM me and ill give you my number. i dont know everything but i can find the solution pretty quick.
Old Jan 8, 2011 | 02:29 PM
slobaltTVS's Avatar
thank you, so far im thinking about ordering the h22a from japanese star motor. would i have to get a new transmission also? also the h23a seems tempting for the extra 300 dollars. would i have to do anything else to make that fit?
Old Jan 8, 2011 | 04:12 PM
IMO, H23a isn't really worth it for the extra 0.1 displacement, H22a is a more direct swap. If your curious about what it takes to swap the H23a VTEC search for the Blue Top Mystery Motor thread, has lots of good info.
EDIT
https://honda-tech.com/forums/honda-prelude-4/jdm-h23a-vtec-blue-top-mystery-motor-true-facts-questions-2341343/
Old Jan 8, 2011 | 04:39 PM
dagle's Avatar
If you're handy with the wrench and can assemble your own motor(s), you'll save a lot in the long run holding out for a little bit and finding a good one to rebuild. IMO finding a motor with a spun bearing and a good crank/mains is better than a stock H22A/H22A4/H22A1. Because at the end of the rebuild you have a motor that has new rings, new bearings, new everything for less than a used motor.
the H23VTEC swap is pretty direct imo if you're OBD1 from what I understand. I've personally owned one and worked on one and the most confusing thing was simply the OBD1 and 2 differences. But given that you're talking about a 4th gen, it should be fairly straight forward. The 0.1 liter displacement doesn't seem like much but the torque makes for a notable difference throughout the low-end and mid-range. If you think about it, picking up 10ft/lb of torque throughout the entire powerband over an H22 is pretty good irght?
Just my 2cents on the idea
Old Jan 8, 2011 | 06:11 PM
slobaltTVS's Avatar
well thank you for the input, ill be looking more into this and what i want to do.
by the way this is what i decided to do with the tail lights, lol and yes its a dealer tag cause they are having a problem getting the title from the dmv right now
Chris Holcomb
Welding / Fabrication
Jan 30, 2013 04:09 PM
jstyl
Feb 27, 2010 08:01 PM
trucdoken
Oct 11, 2007 11:01 PM
prospeed
Mar 4, 2002 09:59 AM
