1988 Honda CRX SI (280Whp)
1988 Honda CR-X SI
5 Speed
Body has 235 xxx
Engine has 20 xxx
I purchased this vehicle with $14,000 invested in it. I am selling the car because I need a daily driver car.
AEM Plug and Play ECU
AEM 3.5 bar Map Sensor
CP 9.5:1 Forged Pistons
Eagle H-Beam Rods
Darton Sleeves
10,000 rpm balanced crank
ARP Head Studs
Cometic .090 mls Head Gasket
Rebuilt Head with 3 angle valve job (Also have a VTEC head not installed)
AEM adj. CAM Gear
AEM Fuel Rail
AEM Fuel Pressure Regulator
Skunk 2 Intake Manifold
Skunk 2 68mm throttle body
660cc Venom Injectors
MSD Blaster 2 Coil
MSD Ignition Box
Nology Plug Wires w/grounding
Fluidyne Radiator
Flexa lite electris fan
Turbo xs dual stage boost controller
T3/T4 Turbonetics turbo with 1000 miles
REV hard cast exhaust manifold (Also have a BRACED XSPOWER RAM HORN MANIFOLD not installed)
ACT Stage 2 clutch (might need adjustment or possibley new clutch)
Fidanza Flywheel
Fidanza 300 torqe axels
Golden Eagle Vacumm block and oil sandwich adaptor
Z-10 Traction bars
Suspension Techniques Front and Rear Sway Bars
Coilovers
Rear Intera disc brakes , cross drilled front rotors
6 point (black) Moly Roll Cage
Apexi Turbo Timer
AEM Ultra lite boost, oil pressure, volts, airfuel gauges
Battery redirected to the rear of the car under the hatch. (Also has exterior battery cut off switch)
Tinted Windows
I also have dyno records
I want to sell the whole car.
5 Speed
Body has 235 xxx
Engine has 20 xxx
Eagle H-Beam Rods
Darton Sleeves
ARP Head Studs
AEM adj. CAM Gear
AEM Fuel Rail
MSD Blaster 2 Coil
MSD Ignition Box
Fluidyne Radiator
Fidanza Flywheel
Z-10 Traction bars
Coilovers
Apexi Turbo Timer
Tinted Windows
wip_customs
Mar 3, 2009 04:50 AM
