How to remove the fuel injector plastic connector?
Old Jan 7, 2011 | 02:21 PM
brucifer's Avatar
Default How to remove the fuel injector plastic connector?
I am having difficulty trying to remove the fuel injector plastic electrical connector on a 94 vetc 4 cylinder engine. How does one do that? I know it has something to do with something called a bail wire clip, that squarish U shape wire that goes around the outside of it. Does it have to come off completely ? If yes, how is it done without losing the clip, flying away from the spring tension? Can I just loosen this wire clip somehow rather than remove it completely to get the connector off and then snap the clip back in place and then reinstall the connector when I'm ready to? Confused
Old Jan 7, 2011 | 08:19 PM
holmesnmanny's Avatar
Default Re: How to remove the fuel injector plastic connector?
The wire clip comes off all u gotta do is pry it back. It does not come completely off, just off the injector connector. Then you just take the plastic connector from the injector.
They appear to be about to break but they don't. They're pretty flexible.
Old Jan 7, 2011 | 09:10 PM
nus_dogg's Avatar
They lock in place by that square clip; gotta move them back to get it to release.
Old Jan 10, 2011 | 05:42 AM
AmunRa's Avatar
Make sure you are extreme cautious while playing with the filter inside the valve, even minute dirt there impacts the performance.. and put oild on the O rings whie putting in back, I ruined 2 of those last time I opened it.
Old Jan 10, 2011 | 06:29 AM
nus_dogg's Avatar
What are you talking about? The OP's talking about unhooking injector connectors and it's got nothing to do with any sorts of valve you're talking about.
Old Mar 1, 2011 | 08:38 AM
brucifer's Avatar
Yep, I'm wondering the same thing. Person is probably referring to the filter screen inside of the injector.
SCMFOX
Dec 21, 2017 09:16 PM
RTW DC2R
May 19, 2006 02:08 PM
