wiring time!
Who the fack changed my title?!
so, can i change my interior wiring harness where it sits closest to the firewall without having to pull the rest of the wiring in the car? meaning my cabin harness. if so how is this done? would like to have a clean connection for my wiring and not some hacked *** job.
You could do that yes. The harness under the dash unplugs from the rest of the car like you said. But it is a lot easyer to just do the dpfi swap to mpfi swap. Add the wires you need it won't look like a hack job if you do it right solder the conection and heat shrink them it looks nice. Just my opinions. Do wat you want tho
hehehe wouldnt you like to know
nah, i was wanting a clean connection all the way across the board. was thinking of redoing my entire car with an obd1 setup lol.
Wowsa. Then I'm pretty sure you have to replace the entire Harness. it will not plug into the rest of the ob0 harness in the car. And. I'm not sure how you would wire up your climent control. Have fun with that project never done nothing like that befor. But good luck
daniel990836
Mar 17, 2008 07:30 PM
