sedan handles on a del sol
alright fellas i need some help here im doing the eg sedan handles on my del sol
and ran into a little problem.. the rod that connects to the handle is too long.. i went to the junk yard to check out the rods and they are completely different..
does anyone know from what car i can get the rods to fit the del sol??
thnx any help would be appreciated!
I don't know much about the Sols but my guess would be you need them strictly from another Sol seeing as the design of the doors is so different.
the problem i have is the rods are too long and cause the door to stay open and not close
thats what im assuming as well.. the rods a little too long so they dont bolt up.. i checked the 4dr eg's and the ej's and theyre waaay too different, now i just need to check an eg hatch and other del sols..
yes thats exactly what im talking about. lol it looks cleaner and harder for thieves to break into.. and oh ok what del sol did he have?? the si or vtec model?? i have an si which is power everything..
I also did this on my hatch. but I just use the stock rod for the hatch maybe you could try one out of a coupe or hatch? but I would just work with the rod you have and bend it a little bit.
isn't one of the bolt holes in a different spot on the handle? on my civic it was. ended up using my own handle. filled the hole at the body shop before painting.
im no thief but i've had to break into my del sol before. i didn't even touch the door handle. worry more about the fact that your window has no top seal and its super easy to get it unlocked. just saying security wise won't help.
i did it with a 1/8th inch rod. i locked my keys in it, go me.
but it will look nicer. good luck.
Forgot my rear windshield was down once and when I came out of the store the change and couple dollar bills in the ashtray were gone but the ipod in the (unlocked) rear compartment was there.
Hope ya get this to work like said befor try bending your rod to get it to work right. I did this on my 91 hatch looks nice direct swap just had to swap out the peace from my hatch handles to the sedan handles that. The rod screws into I don't kno wat that peace is called lol
ToPNoTcHTeChNIk
Apr 30, 2009 04:28 PM
