smells like poop...
Old Sep 23, 2002 | 08:47 PM
LD_EGSICK's Avatar
Default smells like poop...
i had my custom pipein done about a couple of weeks ago...n now, well i just notice it, while the car is running the exhust smells like ****..like its a gas kinda smell...n i just got a new use distributor on my moter....soo i think its cause my timing off...
[Modified by mysiqu, 6:02 AM 9/24/2002]
[Modified by mysiqu, 6:07 AM 9/24/2002]
Old Sep 23, 2002 | 08:54 PM
Chris's Avatar
Default Re: smells like poop... (mysiqu)
install your Catalytic converter
Old Sep 23, 2002 | 08:58 PM
MrTodd's Avatar
Step 1: Sell your car, and use the money for Step #2...
Step 2: Go back to 3rd grade and learn the english language, there are thing's called punctuation & grammar.
If your exhaust smells like fuel, then you're running rich. Check your timing - new ignition components would'nt hurt either (plugs, wires). If that still doesn't do anything, a new O2 sensor and maybe even a new catalytic convertor should be in order...(considering your motor is mostly stock)
[Modified by MrTodd, 11:01 PM 9/23/2002]
Old Sep 23, 2002 | 09:05 PM
LD_EGSICK's Avatar
dame man....sorry i an't all that good with my vocab and ****....i'm just trying to ask for help...and yea i still got my stock cat......
Old Sep 23, 2002 | 09:12 PM
MrTodd's Avatar
Okay okay... Sorry. It just bugs me that's all.
Anyway, start with the most simple things. Check out that timing! After that definitely get new spark plugs (because your old ones will have a nice carbon buildup by now). If your exhaust still smells like fresh gas, then I'd say it's probably the O2 sensor....
[Modified by MrTodd, 11:13 PM 9/23/2002]
Old Sep 23, 2002 | 09:18 PM
LD_EGSICK's Avatar
well thanks it wasn't a big deal...i just have a hard time and all...well i got the bosh platium plus fours(how ever u spell them), and i been using them for about 2,000 miles or alittle more...i got a lot much to spend but from my accident it mess up my set up and every thign i got i got to work for....well i went for go n for show...n still got some little things to get done...
-i got about 195,000 miles on my car. get the head done for free from my teacher from school...i was thinking of getting cam gears and soo on...n e one got n e tips on wat should i do?...i wanana super charge my car in the futrue...
-oh yea any one trying to have a ef meet up? in va/dc/md...don't see muchef hooked up around here....except rice out ones with stickers all over it......
[Modified by mysiqu, 6:20 AM 9/24/2002]
[Modified by mysiqu, 6:23 AM 9/24/2002]
Old Sep 23, 2002 | 09:21 PM
MrTodd's Avatar
Okay, for the plugs DON'T use Bosch!
Definitely use the Honda recommended ones! NGK! Just head to checker/autozone and tell them which car you have - ask for the NGK plugs.
The Bosch Platinum +4's run very very cold, these are the worst plugs you can get for a stock A6 motor.
Old Sep 23, 2002 | 09:25 PM
LD_EGSICK's Avatar
thanx for the info.....yea i heard they are only good on euro cars...
Old Sep 30, 2002 | 04:37 AM
NOSED_CRX_VTEC's Avatar
Your cat may be on it's way out or your engine may be running at to higher fuel mixer (e.g. your o2 sensor may have picked up or you not firing on all 4 check HT leads and plus dizy ect)
skymanAR
10
Jun 7, 2013 12:14 AM
1990CamaroRS
Oct 25, 2008 06:40 AM
turtleb16a
41
Mar 15, 2003 07:18 PM
