Speedometer Not Working 95 Honda Accord!!!!
Old Jan 6, 2011 | 12:47 PM
MidnightBlaz3's Avatar
Default Speedometer Not Working 95 Honda Accord!!!!
I have a 1995 Honda Accord the speedometer stopped working due to a burnt wire under the hood it was not on the side with the VSS it was on the right side down deep the wires were the green white ect. now i cannot find where they are now, it had been some time since the problem started i just didnt jump right on it it was working intermittently and everytime i got out of the car after it had been running i could smell the plastic burning from the wire i looked and noticed tht they were burnt so i kinda got mad and reached down there and wiggled it pretty hard then it quit working completely i need to know what part to order so i can fix the problem......... Thanks, Shawn
Old Jan 6, 2011 | 01:14 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Speedometer Not Working 95 Honda Accord!!!!
So you don't know where the wires are, you don't give a good description of where they are and you ripped out the wire and broke it completely?
Find the broken wire and fix it wherever the break is. Solder a new section in and use heat-shrink. I don't think based on your description anyone is going to be able to do much.
Old Jan 8, 2011 | 05:43 AM
sivtechatchy's Avatar
look down at the vss i gurentee u the wire are stuck in the loom cut the take back a lil then pull loom back from wires
karrar55
Jun 11, 2011 01:56 PM
gvox
Jul 13, 2006 12:12 PM
supernet33
Audio / Security / Video
Nov 12, 2005 11:47 AM
supernet33
Nov 10, 2005 03:33 PM
