1995 Accord RPM's violently "Spike"
Old Jan 6, 2011 | 12:46 PM
loxienouis's Avatar
Default 1995 Accord RPM's violently "Spike"
I have a Honda Accord, Automatic Tranny, 220,000+. When I am accelerating from I believe 2nd to 3rd gear (roughly 20 to 35mph), the my RPM's suddenly spike up or second. This also seems to happen when I am accelerating out of very hard Right-Turns....particularly onto a local Freeway on-ramp for example unless I do it very slowly.
The car runs very well otherwise and doesnt shift too hard. Good power and gas mileage.
It did this right after I bought it and I had the Tranny fluid replaced immediately in April of 2010 and it didnt change anything.
Is it my Clutch? Full Transmission going out? Or something else.
Thanks,
LN
Old Jan 6, 2011 | 12:48 PM
akkordjoe's Avatar
Default Re: 1995 Accord RPM's violently "Spike"
ur tranny is ****ed ive went through 4 before i did manual swap
Old Jan 6, 2011 | 12:50 PM
redbull-1's Avatar
So, are you saying the car also shakes/vibrates and not just the tach jumping?
Old Jan 6, 2011 | 12:58 PM
loxienouis's Avatar
No, the car itself doesnt shake at all. Just when I am accelerating sometimes the RPM's just rapidly spike for a moment.
Old Jan 6, 2011 | 01:04 PM
redbull-1's Avatar
Does it seem like the transmission to you? A lot of the 5th gen Accord automatics did not have much problems. Otherwise, if it is just the tach jumping, it could be the distributor, Vehicle Speed Sensor (VSS), or the tach circuit board.
Old Jan 6, 2011 | 01:07 PM
loxienouis's Avatar
I dont know if its the Transmission or not which is why I signed up here. I am almost a complete simpleton when it comes to cars.
The car shifts fine otherwise and has great power on and off the Freeway.
Old Jan 6, 2011 | 01:09 PM
redbull-1's Avatar
It's the "violently spike" wording you are stating to kind of make me think this may not be a transmission problem. Check the VSS connector, which is located on top of your transmission. Make sure it is tight.
http://techauto.awardspace.com/vss.html
vietelement
Texas -OK -LA (Sales)
Jun 6, 2013 08:13 PM
DamTru
Jul 14, 2011 06:31 PM
vcguy28
Feb 23, 2010 07:24 PM
masterkill455
Feb 20, 2009 10:37 AM
