Shop floor coatings?
New building. Has mixed automotive & warehousing. I would like to know what people are using for floor coatings and how they like them? Interested in like a gray with the sand like non skid type surface.
That colorchips site looks interesting (www.originalcolorchips.com). Do you guys run forklifts over it ever?
We just used Sherwin Williams for half of our new shop. Five days later it was flaking up. Sherwin Williams rep has been handling it.
The stuff has a great quality to it, but it's all about the rep forumulating it right for your conditions to establish proper adhesion.
It appeared we used about 9 gallons to cover 3.5k-4k sq/ft at about 175.00/gallon. We used some cheaper stuff that was a three part primer, sealer, coating that seemed to work better for us than Sherwin Williams' all in one solution. With the three part stuff it came out to about 125/gallon but took three times as long to apply so paying staff is a consideration.
I have worked in shops with other types of flooring paint and nothing has held up like this. I would recommend it to anyone. But make sure your rep comes out and looks at what you are doing first. Ours was able to make many suggestions and came during the entire process to confirm it was going good. I am 100% pleased with the product and service.
I just knowticed you said it was one step??? it must not have been the same product we used. We did a thinned down base coat. Then a full strength top coat added the flakes on this step. Then did 3 coats of polyurethane I believe.
The owner of the building who I am leasing from covered the job when I offered to go into a lease option to purchase. His crew did the job and I think they half assed the prep. On the other hand, the Sherwin Williams did some test patches and felt they established the formulation we needed. No sooner is it laid on and there's bubbles. They changed the mix, bubbles are reduced but not gone.
Like I said, the rep is handling it. Sherwin Williams is at fault apparently though, because they are issuing refunds and new material so. It's too bad too, because the stuff is nice where it actually sticks....lol.
Make sure you prep the concrete! It needs to be cleaned and then etched with muriatic acid. It's just like painting bare steel. The U coat it and Griot's garage both seem to be some of the best.
Immediately after. The acid wash is more for pH neutralization than etching. With the ucoatit products the bond to the concrete is made by laying the first coat on a damp floor. So some of the epoxy actually soaks into the concrete.
www.garagejournal.com
Go on the forum and read through the flooring section.
I Used Benjamin Moore, we did the prep right, so no chips or anything to deal with however it stains very easily. If I were to do it over I would use a concrete stain and not an epoxy.
I used a PPG A&B product on my garage floor. It has held up very well over the past few years. Gasoline, oil, etc. I don't recall the name but i went into Pittsburgh paints and asked them for their best stuff.
marcin
marcin
We most recently spec'd the General Polymers TPM #115-U4 troweled mortar system with their Novo-Flo textured chemical resistant topcoat for a laboratory at a Valvoline manufacturing plant.
http://www.generalpolymers.com/products/pdf/tpm115u.pdf
The sales rep for your area can help you determine the best application for your facility. I just recently saw the Valvoline lab and the floor came out really nice.
Here's a mid-painting shot:
JonnySBeee...
Welding / Fabrication
26
May 18, 2005 08:52 PM
Sucka Free
Jul 16, 2002 08:39 PM
