93 Civic 4DR LX Brake Upgrade Question
Old Jan 6, 2011 | 10:32 AM
streethondar's Avatar
Default 93 Civic 4DR LX Brake Upgrade Question
I have 1993 Honda Civic 4DR LX and i am dropping a B18B form a 1995 Integra RS into it. I want to do a front and rear brake conversion on the civic using the rotors and such off my integra. What all do i need to do this and is it plug-n-play?
Old Jan 6, 2011 | 11:29 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 93 Civic 4DR LX Brake Upgrade Question
The rotors and such off your Integra.
I'm sure the answer to your question is somewhere in the FAQs.
Old Jan 6, 2011 | 11:32 AM
I just thought i would ask cause my Civic is a 4Door and My Integra is a Coupe.
Old Jan 6, 2011 | 11:44 AM
Str8EJ's Avatar
To transfer only the brakes, you'll need to swap over the front knuckles (pnp), rear trailing arms (pnp) & e-brake cable. I would recommend changing the lower control arms, also, in order to accommodate sway bars - which I'm not sure the Civic was equipped with originally.
Check FAQs, since you'll need to understand your options for m/c, booster, prop valve, etc.
Old Jan 6, 2011 | 11:46 AM
I am just going to use everything off my integra for the brake swap!
Thanks guys!
streethondar
Jan 13, 2011 05:49 AM
90civicstdgold
Jan 13, 2010 10:18 AM
IChazI
Mar 22, 2008 12:41 AM
Civicman86
Apr 29, 2007 07:49 AM
