calling all b18 crx's?
Old Sep 23, 2002 | 08:39 PM
niceguy
Guest
Posts: n/a
Default calling all b18 crx's?
hey guys, i have a few questions. first off what modifications needed to be done to get the b18 in,does it bolt in? how much did total cost run,installation and engine? Is there a website i can go to read about b18 swap?thanks
Old Sep 23, 2002 | 08:56 PM
Ben Ogle's Avatar
Default Re: calling all b18 crx's? (niceguy)
http://www.hasport.com
Ben
Old Sep 24, 2002 | 03:42 AM
SuperCivic's Avatar
it's actually really easy. you need a mount/linkage kit..look up hasport for this. you'll also need axles..source 90-91 integ axles and intermediate shaft. get the teg ecu, then if you have an Si or HF everything will plug in. if you have a HF or STD you'll need the front hubs as well. check out the hybrid pages.. hybrid.honda-perf.org
Old Sep 24, 2002 | 10:12 AM
blackturtle916's Avatar
Default Re: calling all b18 crx's? (SuperCivic)
dont forget to hammer the spot for the alternator pulley
Old Sep 24, 2002 | 10:49 AM
1st-hybrid's Avatar
Default Re: calling all b18 crx's? (blackturtle916)
Or if you do forget, use an air hammer/chisel to correct the problem.
Old Sep 24, 2002 | 11:34 AM
giooooo's Avatar
Default Re: calling all b18 crx's? (1st-hybrid)
um this is ot.. if you have a b16 jdm tranny what throw out bearing do you use? 90 91 integra?
firejackal
Jul 12, 2012 10:11 AM
Mr. Giggles
Mar 6, 2006 01:58 AM
donaldmejr
Aug 28, 2005 03:10 PM
Ransom
Aug 23, 2003 11:54 AM
project dc2
Aug 5, 2003 05:57 PM
