Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
92 Integra GS 5sp
Old Jan 5, 2011 | 11:41 PM
90teggyls5's Avatar
Default 92 Integra GS 5sp
I have a clean 92 integra gs all power with sunroof. Black interior is perfect, just needs to be wiped down. Body is straight except for drivers side fender, car is red. If you do body work it might be fixable, otherwise can replace. Was completely stock when I bought it. Had ~130k on motor and is now at about ~140. Cluster says 10k less because we changed out original cluster with bad gas gauge. Has a stage one clutch put on when bought. Also dropped it, threw a pacesetter header and intake on it, and installed a short throw shifter. Wired for system. Runs good, did tune up such as plugs, wires, cap&rotor. Also replaced bad water pump, timing belt, thermostat, etc. Only things bad are: no AC(everything is there, need new compressor), ride could be smoother(have tokicos struts for front, need forks from civic-go with car if sale), fender, drivers front lower turn lights casing is broke. This is a pretty clean DA esp for its age. Hasn't been all riced or ragged out. $2300obo. call/text 8175077989. Clean Texas title.
Old Jan 9, 2011 | 07:45 PM
90teggyls5's Avatar
Default Re: 92 Integra GS 5sp
bump
Old Jan 9, 2011 | 07:52 PM
90teggyls5's Avatar
Will entertain offers but no lowballs.
jardine90si
Appearance Build Threads
50
Dec 17, 2010 04:09 PM
eg_21
Nov 11, 2010 04:37 PM
underage
Northeast (Sales)
13
Mar 24, 2007 02:18 PM
underage
Mid-Atlantic (Sales)
Mar 23, 2007 02:05 PM
vltnolia
Jan 22, 2004 01:25 PM
