B series comp cam dual valve springs ONLY (new)
Zex/Comp Cam has the ultimate set of valve springs for your high performance B-series Acura/Honda engine. Whether you’re running 30 lbs. of boost or revving to 10,000 rpm, ZEX valve springs have the correct design to ensure proper valve sealing in any application. Made with the highest quality, superclean, chrome-silicon steel, ZEX springs are made to handle lifts up to .500 inch. The premium quality material we use, allows our springs to last with the incredible valvetrain loads that today’s racing cams produce.
1.171" Outside Diameter / 0.615" inside diameter
Installed 60lbs. @ 1.375" / Open 220 lbs @ .875"
Spring rate 43 lbs./in. @ 1.375
Dual spring assembly for intake and single for exhaust open 148 lbs. @ .875
viera
Jan 9, 2011 09:00 AM
civic00sir.
Mar 19, 2010 09:59 AM
jt-sport
18
Jan 30, 2006 12:09 PM
hondaboyB18C1
Dec 8, 2003 04:02 PM
