OBD1 JDM B16A Full Swap! CHEAP!
Yo..wats the difference with a b16a2 to ur jdm b16a ...Is it just the usdm version or is ther a sik advantage to it,,like displacment or something performance like that...LMK cuz i very interested....
BUMPER and GLWs
BUMPER and GLWs
B16A2 (USDM):
- Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
- Compression: 10.2:1
- Power: 160 hp (119 kW) @ 7600 rpm & 111 lb·ft (150 N·m) @ 7000 rpm
- Transmission: Y21 or S4C
- Redline: 8200 rpm
- Rev Limit: 8500 rpm
- VTEC Engagement: 5,600 rpm
- Aluminum Casting
- ECU Code: JDM P30 (square case) or USDM P30 (regular case)
- Compression: 10.4:1
- Bore: 81.0 mm (3.2 in)
- Stroke: 77.4 mm (3.0 in)
- Rod Length: 134 mm (5.3 in)
- Rod/stroke ratio: 1.745
- Power: 168 hp @ 7,800 rpm & 16.0 kg·m (157 N·m; 116 ft·lbf) @ 7,300 rpm
- VTEC engagement: 5800 rpm
- Redline: 8200 rpm (AT: 7700 rpm )
- Transmission: S4C/Y21/S21 (4.4 final drive, optional LSD)
- OBD1
