rpm/tachometer problem
Old Jan 5, 2011 | 02:44 PM
Honda177's Avatar
Default rpm/tachometer problem
hey guys need help with my rpm i have a 95 civic the problem is that my rpm wont work what can i check to find the problem ?
Old Jan 5, 2011 | 02:49 PM
grumblemarc's Avatar
The Grumpiest
Default Re: rpm problem
That tachometer won't work?
Old Jan 5, 2011 | 02:56 PM
Honda177's Avatar
everything else works its just the rpm messing up
Old Jan 5, 2011 | 03:03 PM
The Grumpiest
"Doesn't work" and "messing up" doesn't tell us anything. Can you be more detailed as to the nature of the problem?
Old Jan 5, 2011 | 04:01 PM
Former User's Avatar
The tach get rpm signals from the blue wire attached to the igniter unit inside the distributor. Check the blue wire for continuity and a short. If it's fine, have an auto parts store test the igniter unit itself. If that's also fine, then the tach or cluster may be bad.
Old Jan 5, 2011 | 04:13 PM
Honda177's Avatar
Default Re: rpm/tachometer problem
oh ok thanks i check that out yeah cause when am moving the rpm stays in 0 it doesn't move at all thanks alot guys sorry if i got you kinda mixed up lol it's just that am new to this things
Volfsburgs
Jun 20, 2014 11:27 AM
CPUv2
Apr 17, 2009 11:59 AM
thesoundofturbo
Nov 26, 2007 12:48 AM
PoWeRBaN_PaNdA
Aug 28, 2002 02:48 PM
