dpfi-mpfi obd1 code 5 car wont start.
Its the map sensor and i tried a spare i have and still code 5. Will this make my car not start? It was idling ruff before but the last 3 days it wasn't and then it would die when i would drive and now no start.
@ Rudy i tried to PM you but it wouldnt let me but did you make ur harness your self? Im trying to find more info for my d16z6 swap.
Civcxtree754. I had some local lame do it and when i asked him to do it i told him obd0 and the lame brought it back grey plug. Anyways he had some wires croseed, it was a nightmare just for going cheap. I endedup having 4 guys and $300 later trying to figure it out. I took it to swapshopracing with a guy named mark and he got it started. My point just go to a well knowned wiring wizard bro. I found out before i went back to work earlier that i had 3 jumper harnesses loose but i plugged them back. Even my grounds are there as well so the only thing i could think of is that i checked my oil and nothing! It was blowing smoke so maybe i lost compression? Maybe the blocks done? It did that last time too and i did an oil change but its drained again man.
odd stuff man, should have hit me up dude, I would have done it for cheap, AND it would have been running right the first time.
Hey i feel like going back to obd0 man. I am looking for some1 to do my ride and since you do harnesses. I am going to grab a zc single cam or d15b this month and i wanna start fresh with the wiring. I think its my wiring tho, cause ive been having problems with that since day 1. I hate this harness
hit me up when you are ready man and we can talk. Depending on what your harness looks like, I can either fix yours, or start with fresh harnesses and go from there.
Here is a full harness I just completed for someone the other day. Cabin and engine harness ready for him to swap in and drive the car....
Man that looks so clean compared to mine. Would you drive down here or would you need to have my car towed cause it would be a mission to tow out there. Im familar with the niegborhood i drive all over there for work sometimes
Oh no problem ill hit u up tomorrow maybe with a pm too so we can set up a time and date. i want my car back out so bad. Its not even about back to the streets. its about getting to work and not having ppl bitch at me for using there rides lol. But for sure clipsed.
sounds good I'll shoot you my number right now.
Edit- guess you have your settings to not be able to receive pms so just hit me up.
WickedWerx
Oct 28, 2004 07:02 PM
turbo charged cars love to gulp gas lol
