Nut size question....
Old Jan 4, 2011 | 05:27 PM
Charlie Moua's Avatar
Default Nut size question....
I'm a dumbass and should know this. My EF is not here for me to confirm, but can you tell me what are the nut/tread size for the shocks and UCA which are visible in the engine bay?
I know there are 4 bolts on each side, 8 total but can't recall if they are ALL m12x1.25 or not.
TIA
yes i tried to search already.
Old Jan 4, 2011 | 05:30 PM
sirtef9's Avatar
Default Re: Nut size question....
14mm nuts at the top of top hats if thats where you mean, the UCA are 17 mm, not sure what pitch that is thought sorry.
Old Jan 4, 2011 | 06:04 PM
not not LCA.... i know the LCA bolt and nut is 17mm
I'm taking about the UPPER (UCA) that have 2 bolts going UPWARD through the engine bay and held on by 2 nuts.....
Old Jan 4, 2011 | 06:11 PM
MRN1120's Avatar
Uca=M12x1.25(17mm head) http://downstarinc.com/Shop/index.ph...d&productId=30
Strut=M10x1.25(14mm head)http://downstarinc.com/Shop/index.ph...d&productId=31
Old Jan 5, 2011 | 06:38 AM
yeah but if you look at EF bays our bolts seem different...
Old Jan 5, 2011 | 10:04 AM
mr2krash's Avatar
"Uca=M12x1.25(17mm head) http://downstarinc.com/Shop/index.ph...d&productId=30
Strut=M10x1.25(14mm head)http://downstarinc.com/Shop/index.ph...d&productId=31"
These sizes are correct
If you think yours are different then maybe someone has swapped them out, these cars are 20+ years old now and whats on those parts might not be OEM honda....just food for thought
10HBmartian
Feb 3, 2012 06:55 AM
owa
Feb 3, 2010 05:18 AM
twentyhurtz
May 9, 2009 11:41 PM
radeonboy
Apr 5, 2006 06:45 PM
m3bluegsr
Aug 28, 2004 12:54 PM
