I'd like to know if I can use H22 stock pistons/rods on an H23 stock crank.
Old Jan 4, 2011 | 04:03 PM
nemesis25's Avatar
Default I'd like to know if I can use H22 stock pistons/rods on an H23 stock crank.
Thanks for looking. Just a noob question. Like the title says, I'd like to know if I can accomplish this? Also, if it is doable, would I need to use H22 rod and main bearings?
Old Jan 5, 2011 | 07:03 AM
4G92's Avatar
Default Re: I'd like to know if I can use H22 stock pistons/rods on an H23 stock crank.
depends on the year the h22 combo comes from. I am not sure why you would do this but i hope you do not attempt to do this...
Old Jan 5, 2011 | 08:32 AM
q16racer's Avatar
Why not? Other than having really high compression it works just fine. The rod journals are the same size. Im using h22 rods
Old Jan 5, 2011 | 10:41 AM
nemesis25's Avatar
The pistons and rods are out of a 94 si vtec, going into an H23 block/crank with an H23 head. The reason for this is cuz I have all these extra parts laying around, and besides, I need a stock rebuild for my 92 si. I really cant afford anything else. So, I need to know if this will work?
Old Jan 5, 2011 | 11:32 AM
H22SHtec's Avatar
i think you may be off on your bore, civic is 84mm and the h22 is 87mm.
Old Jan 5, 2011 | 01:26 PM
nemesis25's Avatar
It's a 92 Prelude si with an H23. Not a Civic si.
Old Jan 5, 2011 | 02:18 PM
q16racer's Avatar
using the h23 head, you are going to run into even higher compression and trying to run it on pump gas may not work in your favor. The combustion chamber on the h23 head is about 3cc smaller and thats if the head has never been milled.
EGeek
Oct 7, 2011 04:37 AM
zo4000
May 26, 2007 08:25 AM
yohan
Sep 23, 2004 11:39 PM
turbolude831
Sep 22, 2004 07:03 PM
JDMBB2
Nov 13, 2003 10:39 AM
