20 splines on tranny..what clutch?
Old Jan 4, 2011 | 12:13 AM
thecruzs2007@yahoo.com's Avatar
Default 20 splines on tranny..what clutch?
ok so ima noob to Ef/Crx chasis just to let ppl know.. but i was helping my friend take his motor and trans out today and we dont have a clue to what clutch to get.. he has a b7 block with z6 mini and i counted the splines on the trans and i counted 20.. soo my question is..can i use the flywheel that came on the b7 and buy a regular hydro clutch?? or do we need to buy an 89-91 flywheel with what clutch??
thanks for any advice..
Old Jan 4, 2011 | 08:42 AM
Projekt_Ef9's Avatar
Default Re: 20 splines on tranny..what clutch?
You are going to need a clutch that matches your transmission. If the splines on the clutch disc is not the same as the splines on your trans it will never line up and go together. If the clutch service is wide enough on the flywheel for the clutch disc to ride on and the pressure plate lines up with the bolt pattern on the flywheel you shouldnt have to change to a 88-91 Flywheel. I ran a JDM D15B with a D15B2 Clutch and pressure plate with a D16A6 flywheel and never had a problem.
Old Jan 4, 2011 | 11:22 AM
96DelSol's Avatar
1988 tranny has 21 splines
1989-91 has 20 splines.
1988-89 have smaller flywheels
1990-91 have bigger flywheels
You have a 89 tranny because you told me you had one groove on the shaft of the tranny.
Meaning you need a 1988-89 flywheel bolted on the b7.
The b7 block is off a 92-95 civic and uses a larger flywheel like the 90-91 ef.
Old Jan 4, 2011 | 11:25 AM
96DelSol's Avatar
The reason it bolted up to the d15b correctly is because you used a 90-91 dseries flywheel/clutch.
90-00 flywheels are the same size.
Old Jan 4, 2011 | 03:29 PM
I used an 88 clutch and pessure plate because i had an 88 trans in it with 21 splines. I have no idea what year the flywheel was it came with the motor. I dont know where u got that i used a 90-91 one from. the splines on the 88 trans are different.
nitewolf
Nov 8, 2007 12:03 PM
vishyncsu
Oct 7, 2004 10:38 AM
luvinmyGSR
Jun 17, 2004 08:08 PM
