Another B20 query
Hello guys
Yesterday i've got myself a b20b3 block
i am planing on dropping a ycp 84mm pistons in it as well as some arp rod bolts and acl race bearings.
I am planning on revving no higher than 8k since my head is a pr3 with itr valvetrain and gsr valves and i dont think it will make power in higher rpms anyway
So my question is am i gonna be ok and what to epxpect from such a poor build
Thank you very much in advance
Hello guys
i have a built b20/gsr its two days old still in my ef. i will make u a deal. you can come see drive the motor,comp test . i come on hard times and need cash for lawyer
pm if interested i will hook it up. heres the build.
84mm b20 block
decked and honed bye a sunnen
gsr crank
i beam lightweight rods
acl bearings
13:1 weisco teflon coated forged pistons
portflow ported b16 heAD
arp head studs
new vtec oil pump
endyne lsvtec kit
skunk 2 valves
brian crower stage 2 cams
brian crower springs titanium retainers
supertech teflon valve seals
aem cam gears
mugen valve cover
cometic head gasket
pm if interested i will hook it up. heres the build.84mm b20 block
gsr crank
acl bearings
arp head studs
new vtec oil pump
endyne lsvtec kit
skunk 2 valves
aem cam gears
mugen valve cover
cometic head gasket
wow man
that's a bad *** build you have
Only problem is i am all the way from eastern europe
Can you tell me why did you use an gsr crank what benefits does it give over the b20 crank
Thanks man
Thanks man
it would help if you jus did what it says and read more
a poor build is gonna run like a poor build
this should have what youre looking for..
https://honda-tech.com/forums/showth...b20vtec+builds
where are you located?
hi guys
My engine is ready now
84mm ycp 11:5:1
type r cams and valves
aebs intake with 64mm tb
walbro 255 pump stock b16 fuel regulator and injectors
some 4-1 header on 2,5" exhaust
i am running on stock b16a2 map from the p30 ecu
however the car runs really weak my b16 was way faster
i am still runing on the first oil since the break in
my question is do you guys think that it is all about tunning from now on or have i messed up with the setup
Ps: the engine is working perfectly, not burning oil or any ****
Thank you in advance
84mm ycp 11:5:1
hi guys
84mm ycp 11:5:1
84mm ycp 11:5:1
ok i hear you guys
i will get it tuned asap
one more question do you think it is ok to hit the dyno only about 300km after the first start ?
Thank you very much for the help
A poor build? I mean, sure it's not all forged components, but these kinda builds have been proven to work really well. Bottom-ends like his are great for the budget builder. With more money into the head, there's no doubt that thing will move. Plenty of setups running 12s and a few doing 11s with "poor builds" such as his.
And OP if you also took the time to read a lil, you'd know a 2.0 needs more fuel than a 1.6 ya big dummy
yeah yeah i know
i just thought that even before i find the time to get it tuned it would feel faster hah
but i guess that aint happening whit this lean bin.
Once again i appreciate your help guys i will post my dyno sheet any day now
guys we have located the problem
My b20 does not have vtec
:D i was confused before becouse the ecu changes the maps in the high revs and the engine gets richer and runs better but in fact we have no vtec
so today we will open the headto see where the problem is because we have checked the vtec valve we have checked the outer oil line so the problem is somewhere in the head
:D i was confused before becouse the ecu changes the maps in the high revs and the engine gets richer and runs better but in fact we have no vtec so today we will open the headto see where the problem is because we have checked the vtec valve we have checked the outer oil line so the problem is somewhere in the head
ok guys i need your help once again
i have checked the oil line and it is ok i have been told that ive i have lost even one pull for the vtec i will loose oil presure and no vtec at all so i am checking that but if not what to look for ?
thank you in advance
because i am really woried
my vtec is not working
i have checked first the ecu and the problem is not there
i have checked the outer oilline and it is capable of 3bar oil pressure so the problem aint there
so tommorow i am planing on checking if i have not lost during the asembly one of the pins locking the rocket arms or if any of the oil lines for the vtec inside the head are clogged
and i am asking for an advice if there is anything else that can be the caouse of the problem
itsjusj0hn
Nov 4, 2007 08:16 PM
jdmoutkast
Aug 21, 2005 11:31 AM
