GC/KONI
hey guys, so i finally decided that i am going Koni/GC.. but i was wondering does anyone else have opinion on what shocks beside koni i can use..
i have a 24 mm sway in the rear and also can i also get reccomended spring rate..
i was think 380 in the front and 250 in the rear.. Also its a EK 97 sedan LX
thanks
thanks
Do you still have the factory 22mm front sway bar?
How low would you like to be? Do you like how the car curruntly drives?
Is it your Daily driver?
Personaly I would go a bit higher, Maybe 400-450 up front and 350-400 in rear, But this is just my personal opinon.
the ground control sleeves have to be specific to koni sports or not
there really isn't a better shock in this price range
what tires are you going to use? need to know for the rates
i don't mean size either, need tread compound or at least a make and utqg rating
btw what's a 97 ek sedan? is that a 97 civic coupe? like 2dr with the trunk?
right now, im running KUMHO ASX
Serv. Desc: 86W
Load Index 86 = 1168lbs (530kg) per tire
Speed Rating "W" = 168mph (270kph)
UTQG: Treadwear: 420
Traction: AA
Temperature: A
420 AA A
sorry, i have a EJ6.. and its going to be DD and maybe auto cross
so i was reading up on some site, they said beside is 350F/300R
as for tire, i will be switching in and out. i think the next setup would be yokohama S-drive or bridgestone G-force
Serv. Desc: 86W
Traction: AA
Temperature: A
420 AA A
damn it, now i have to google what an ej6 is....okay a civic coupe, let's see what this thing weighs ....2650 ish...okay it will set up just like an integra, i've never liked the whole vin tag body code thing..too much crap to memorize
with those rocks of tires you have stiffer springs are going to make the car communicate less and not really do a lot to improve time. 300/250 would work and or 350/300
380/250 is an understeer combo
use an 8" ers spring in 350/300 which will also be a good match if you get a sportier tire like the s drive. if you had someone else say 350/300 for your setup i second the motion. that's a good combo at your weight with those tire choices and that sway bar
rates up around 500/450 are really designed for yoke advan ado8, kumho xs level tires that can benefit from that reduced body movement. with a harder tire 350/300 is still going to feel sporty but you will have some body movement that will help you feel what's going on with the tire.
i actually have a EJ6 sedan.. its a 4 door. and i think my weight is.. 1997 Honda Civic LX SDN AT 2387. i found it on google.
i have a sedan not a coupe
and its auto for now
yeah i think i will stick with 350 F and 300 R
hmm...looking....found one weighed at 2438...2392...wonder where that first tool came up with 2650. well, if you're at 2400, the game still applies, it just will feel slightly stiffer than at 2650...i agree 350/300 is the way to go.
order em up
order em up
alright thanks for all your help man.. its been about 3 month since i research all these suspension part..
was looking at Megan EZ street. D2 RS...Ksport...Tein and these.. but the more search i do, i think i feel more comfortable with these koni/gc.
420 treadwear and 24mm rear sway? Sounds like a recipe for massive lift-throttle oversteer. Be very careful around sweeping corners on the street, especially when it's wet.
no i have a 24mm sway and its going to be DD
right now, my current setup is kyb with eibach protkit.. im probably going to stick with the same height of drop
oh btw, i missed type. i have a EJ6 sedan
mynameizstitch
Suspension & Brakes
Dec 14, 2009 09:00 AM
