1989 Hona civic EF parts OBO all!!!
hey guys these parts are all OBO i want them gone by the end of this month if they are still here by then well junk yard it will be.
The trans- i dont know much about i can get the numbers off of it,i was told it will need to be rebuilt.
The block- is in good shape,needs honed other then that its good for a build or extra block and it is a D15b and i can get more pics of anything you would like.
The head-i do have the vavles,springs for it.i did start porting and polishing it and i never got done with it but someone could take there time and do a great job and have a good head.
The dizzy-Just for parts only the housing is cracked
The gear-is for the oil pump still good just needs cleaned
1: napa axle not used that much
2: stage one exdy clutch with prusser plate
3: head
4: block
5: trans
6: cam with gear stock
7: oil pump pick up
8: stock crank with flywheel aftermarket 8LBS
9: shifter and bar all in one little rusty but would clean up and new paint,good as new
10: oil pump dont know miles but still worked when tooken off and looks good still
11: bottom timing cover still good just needs cleaned
12: oil pump gear
13: dizzy
14: rocker assembley
15: water pump still worked when tooken off
ALL PRICES ARE OBO OBO OBO
3: head
4: block
5: trans
7: oil pump pick up
12: oil pump gear
13: dizzy
