saving a prelude
my friend owns a 1998 5th gen prelude with an h22a4 swap running about 160xxx miles. when he bought it, it had a slight ticking noise so the first thing we did was add some oil and give it an oil change.
the ticking didnt seem to change so eventually we did a cam adjustment on it. even after the cam adjustment its still ticking.
also it had an oil leak i believe may be coming from oil pan which recently got severe. maybe its just a gasket, hopefully not a cracked block.
also its leaking break fluid from somewhere on the clutch which is progressively getting worse.
its a dd so i havent had a chance to really look at it yet but i will sometime in the next few days. i was hoping to get some feedback from someone with a similar experience or who knows this engine or knows about engine swaps.
yes i have searched.
tips or help on any of these problems is much appreciated.
check the rear main, mine is losing some there. sounds like the line for the slave has a leak, either that or the slave its self. the ticking idk, i got the same thing tho.
good luck
good luck
get your fuel from a reputable place like bp, amoco, shell, texaco and make sure you have the correct octane.
