electrical help - brake lights wont turn off
First off let me just say.
i checked all the fuses and none are blown.
now lets get to the problem
I am having to take out my rear brake lights because they wont turn off.
This runs my battery down, and it is unsafe at night.
with this being said
when i open the driver door, the interior light doesnt come on.
the dash lights are a little dim, but work.
any help.
could it be an old alternator?
any help.
have you checked the push type button under break pedal to see if its stuck or is bad thats what causes the break lights to come on and go off when appling and letting off the brakes.
usually they just get moved like when u press the brake in it lets out on the push button and lights come on then when you let of the brakes it pushes the button in and they go off. and itll be toward the top of the brake assemble
ok. i hope thats it.
the driver side did it.
then i took the eg for a ride today and noticed the pass. side did it lol.
so im sure thats what is sounds like.
thanks for the help.
one problem at a time!
check the brake light switch on the pedal.. see if it is bad. if it is good and they are coming on then find the short.
is the interior light bulb blown? is it's fuse? if no, find the short
how dim are the dashlights? what kind of car is it? they aren't bright as a new cars to begin with...
try that or make sure the clip didnt break that holds the push button in place cause that may have it akward and why its not lined up also
i hope so too.
i crawled underneath, and had my brother stand out side.
i had to push the brake down a little bit to get my finger to push the button, and sure enough, the lights came off.
HatchBeezy
Jun 11, 2003 10:26 PM
