Steering wheel shake at high speed??????
Old Jan 3, 2011 | 08:59 AM
black94lude's Avatar
Default Steering wheel shake at high speed??????
Hello guys, I have a problem with my 99 civic EX. The past couple of weeks ago my civic steering wheel started to shake when you hit high speed (70 mph). From 0-65 mph the steering wheel does not shake whatsoever but when you hit 70 mph and on the steering wheel shake so much. I have rotor and balance my tires but it did not fixed the problem the shaking is still there. I don't know what is causing it to shake. Can anyone please give me some advices, I really appreciate it. Thanks
Old Jan 3, 2011 | 09:09 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Steering wheel shake at high speed??????
Strut/bushings bad? Is it coming from a particular side?
Old Jan 3, 2011 | 09:38 AM
I don't know exactly what side it is coming from. I can't really tell whether is coming from the passenger side or the driver side because when you hit 70 mph the only thing you notice is that the steering wheel shake only. So I can't really tell. Do you think could it be an axle is bad????? Thanks
Old Jan 3, 2011 | 10:50 AM
habib's Avatar
Originally Posted by grumblemarc
Strut/bushings bad?
This or a bad axle
Old Jan 3, 2011 | 11:57 AM
Can a bad axle cause the steering wheel to shake at high speed (70 mph)...???
Old Jan 3, 2011 | 12:41 PM
mattliston's Avatar
yes a worn though usable axle can vibrate at higehr speeds.
othing to worry about if its the axle.
the steering wheel shaking though, it probably is either an unbalanced tire or tie rods are going badd.
a rarety is the rack and pinion bushing so bad it magnifies the vibration at 70+mph
Old Jan 3, 2011 | 01:08 PM
Oh thanks. I take the car to have the tires rotor and balance tomorrow and I get back to let you guys know to see if it solve the problem. If not I try something else. Dang this problem is driving me nuts.....But once Thanks I really appreciate all you guys help.....
Old Jan 3, 2011 | 01:19 PM
EkLanta's Avatar
You should also get the car alighted, might be that your car is unaligned and the wheels are fighting each other to stay straight. If that makes scene to you.
Old Jan 3, 2011 | 01:23 PM
thbx59's Avatar
This happened to a family member though it was more like 50mph+, after struts is was fine (not even an alignment).
Old Jan 3, 2011 | 01:40 PM
blowededup's Avatar
Tie rods are my guess.
Old Jan 3, 2011 | 01:43 PM
Thanks guys for the advices and information.......I really appreciate it....
Old Jan 3, 2011 | 02:31 PM
Red_Army's Avatar
or if you just moved to a snowy area, snow will do this.
otherwise go over whats been stated.
Old Jan 3, 2011 | 03:05 PM
blackoutt2000's Avatar
I just picked up a 99 ex coupe that does this too, right around 70mph the wheel will start to shake for a couple seconds, smooth for a couple seconds, then shake for a couple seconds ....
I haven't done anything to it but there was a receipt in the glovebox for a new control arm and alignment recently, and it just passed NYS inspection so I'm guessing the tie rod ends and brakes are fine. My guess is out of balance or bent wheel, or an axle maybe? Are they hard to change?
Old Jan 4, 2011 | 06:03 AM
Changing a axle is not a problem for me. It not that hard to change the axle.........
Old Jan 4, 2011 | 03:31 PM
slayerfromhell212's Avatar
most of time its a wheel bearing check that out 70+ for sure its wheel bearing
Old Jan 4, 2011 | 03:42 PM
XYRS2LT's Avatar
I have seen warped rotors do this, a bent wheel, or the aformentioned suspension parts. Get your rotors turned, if that does not cure it try rotating your tires front to back, then test drive it again. Also, have seen a seperated tire do this as well. Try these and let us know what the problem is.
Old Aug 1, 2013 | 10:17 AM
f1jedi's Avatar
try removing your brake rotors and see if the problem persists, lol IM KIDDING!
my car has this issue and here is the list of what a mechanic told me is wrong, upper right front control arm, most of my bushings, and a ball joint (lower right front) most of this likely caused because i drive it like i stole it lol
Old Aug 1, 2013 | 10:19 AM
The Grumpiest
Nice story. Let's hope he figured it out by now.
Old Aug 1, 2013 | 10:38 AM
crazyhouse2011's Avatar
By separated tire do you mean one that falls off?!
Old Aug 1, 2013 | 10:40 AM
The Grumpiest
Couldn't Google this before you asked such an obvious question?
It's where the tread separates from the belt/rest of tire.
You don't know a lot about cars at all do you?
Old Aug 1, 2013 | 10:47 AM
Ugh.... this guy.... ^
Old Aug 1, 2013 | 10:51 AM
The Grumpiest
Yeah. If I were you, I'd hate me too. Try educating yourself before asking simple questions.
Old Aug 1, 2013 | 12:43 PM
strategy400's Avatar
We call those alligators because they jump up and bite the side of your car.
Aeolian
Honda Civic (2001 - 2005)
12
Feb 15, 2017 10:57 AM
lildragon'07
13
Jun 2, 2010 08:31 AM
aZnAcCoRd02
May 17, 2007 07:09 PM
jpopson43
Apr 20, 2007 05:41 PM
cbmprelude
Suspension & Brakes
Feb 8, 2007 04:58 AM
