H22 feels sluggish
Old Jan 3, 2011 | 08:10 AM
ilikehonda's Avatar
Default H22 feels sluggish
(posted in the All motor forum as well)
OK, after a dyno tune the car feels sluggish.
Setup
JDM h22
ported head, flat valves, s2 valvetrain, s2p1cams (degreed using max lift), s2 gears
black trax intake mani
70-65mm tb
hytec rep header
Car made poor power 198whp, 156 tq on a dyno jet.
A/F is 12.2 at WOT at 4k and tapers to 12.0 at 8k.
If I remember right the car is running 31* timing.
Vtec is set at 5600.
I can email the file if anyone wants to look at it.
Timing was checked and its right on.
Ideas?
Before the header and intake mani the car ran really well and loved to rev now above 6k or so it just feels like it is fighting to make power
Old Jan 9, 2011 | 08:04 AM
mafia's Avatar
Default Re: H22 feels sluggish
Originally Posted by gceniceros209
idk
LMAO, If you don't know then don't post anything.
Old Jan 9, 2011 | 09:03 AM
Acidcrakker's Avatar
Who tuned this thing. You set timing at 31 degrees?
Seems weird, stock timing calls for 15 degrees.
Also why are you running 12.5 af before 4k. You should be more like 13.0.
Old Jan 9, 2011 | 09:08 AM
q16racer's Avatar
he is referring to the speed density tables, not base timing.
Old Jan 9, 2011 | 09:10 AM
Ok.
Old Jan 9, 2011 | 10:41 AM
92civlude's Avatar
Have you rechecked the cam timing? If the intake cam is off, youll never know through ignition timing. I had an OBD1 Accord in the shop that ran weak. Fuel pressure, exhaust, timing all ok and no MIL. Turned out the distributor was causing the car to run sluggish. I installed a new sub-assy, problem fixed.
Old Jan 9, 2011 | 12:22 PM
serjey15's Avatar
The same thing happened to me.
I have a h22a1 prelude with intake and exuast and p28 ecu.
It seemed to have alot of lowend tourqe but after 6000rpm it was so slow and the engine sound almost changed, sounded like it was trying so hard and someone was holding the ebrake. it was really slow.
Then I went and got my ECU chipped and dyno tuned and now its smooth power all the way untill redline
honda_12V
Engine Management and Tuning
Mar 7, 2013 08:40 AM
ilikehonda
17
Jan 5, 2011 06:26 PM
matix
29
Jun 3, 2005 10:45 AM
civlude_h23vtec
Apr 18, 2005 05:31 PM
