Suspension & Brakes Theory, alignment, spring rates....
Koni/gc help?
Old Jan 2, 2011 | 02:12 PM
hawaiieg6's Avatar
Default Koni/gc help?
I am having trouble with my ride height no matter what I do I can't get my passenger side as low as my driver side it's about an inch higher and I have put the shock and coilover on the lowest setting and it seems to have no effect on it and is still an inch higher does any one have any info that can help me out thanks
Old Jan 2, 2011 | 02:55 PM
90_EX_Civic's Avatar
Default Re: Koni/gc help?
why not raise your driver side to match your passenger side?
also this is known to happen. think it's cause your bushings in your suspension on that side have gotten soft and such. only real way of fixing it is to get new bushings.
Old Jan 2, 2011 | 03:35 PM
hawaiieg6's Avatar
Cause I want it to be lower lol I was also thinking I notice the bump stop is touching the shock already I was thinking of cutting the Koni bump stop and which bushings are you talking about
Old Jan 2, 2011 | 03:36 PM
racebum's Avatar
if depending on the spring length, the lowest setting might have your car to the point your arms are hitting the frame. what you said isn't normal and either you have mis matched springs or you have different lengths on each side
Old Jan 2, 2011 | 03:42 PM
hawaiieg6's Avatar
I check that also I put both springs next to each other and there the same length
Old Jan 2, 2011 | 03:44 PM
98civdx's Avatar
Master Detailer
Koni's have these little groves (cir clip) are they both on the same one?
One on the highest and one on the lowest would do it.
Old Jan 2, 2011 | 04:18 PM
hawaiieg6's Avatar
Ya there on the same I also put it on the last clip and it still wouldn't make a difference I feel like something is stopping it from going any lower I just don't no what it could be
Old Jan 2, 2011 | 04:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
With adjustable coilovers, you always have to set the perches at different heights to get an even ride height on each side. So if you've got them both maxed out down at the bottom (which puts both perches at the same height), the left side will always be lower.
That's just how it is.
What springs are you running? I was pretty damn low when I had GC's with 8" 380 lb. front springs, and the front Koni circlip set to the TOP setting. I could have gotten another 3" lower, which would mean the upper A-arm and axles would hit the unibody/frame before the springs were fully loaded.
Old Jan 2, 2011 | 05:31 PM
hawaiieg6's Avatar
Not sure the spring rates there not custom there just the basic of what ever gc sends u and right now it's not on the lowest setting I'm going to try and mess with it tomm to see if I can get it even I just don't want to go that low on the shock clips cause it will make it ride bad
Old Jan 2, 2011 | 05:55 PM
racebum's Avatar
that's an 8" in front and 7" out back combo set fairly close to the top in front
Old Jan 2, 2011 | 07:42 PM
Community Builder
whoa whoa hold up, you want to totally slam the car to the ground, yet you're concerned about moving the Koni circlips down making it ride bad? lol moving the circlips won't make much difference in ride quality than where you're already at if you have the GC perches at the extreme lowest setting.
Old Jan 2, 2011 | 08:02 PM
hawaiieg6's Avatar
I never said I wanted to slam my car i just want to make the passenger side close to even to the driver side right now both shocks are on the 4th slot counting from bottom up I can't go that low cause my oil pan will hit
Old Jan 2, 2011 | 08:32 PM
are you trying to tuck tire? going for the hella flush look? if you have the money just take it to a shop that can corner balance the car to the height that you want.
Old Jan 2, 2011 | 08:47 PM
hawaiieg6's Avatar
I want to tuck thread not really tire cause since my oil pan is so low I can't tuck tire and I'm not a fan of letting other ppl working on my car I'm going to mess with it more tomm and see if I can fix it
Old Jan 2, 2011 | 08:57 PM
i can understand the other people on your car, but you should know, not every shop knows how to corner balance. it's mostly a racing shop, or a shop that deals with guys that race.
trust me, when you see them bring out sand bangs, and ask how much you weight. they are legit.
Old Jan 2, 2011 | 09:10 PM
hawaiieg6's Avatar
Very true I got to look into it and see if I can find a place in Miami that does that thanks
Old Jan 3, 2011 | 06:06 AM
Community Builder
You said you had the GC sleeves maxed as low as they would go, but you said you wanted to go lower rather than bringing the driver side up to match the passenger side.
Sounds like trying to slam to me. Do you have really tall springs or something? I had 8" front springs (pretty standard fare for most Hondas on GC's) and I could have slammed my Integra to the floor if I had gone all the way down on the sleeves.
Old Jan 3, 2011 | 08:25 AM
hawaiieg6's Avatar
Yes but I'm not low on the shock and like I said I'm not trying to slam it wish I could cause it would look alot better with the wheels I'm on but since my oil pan is so low I cant slam it
bl1tzk1213g
Suspension & Brakes
Dec 13, 2007 03:19 PM
civexspeedy
Sep 1, 2007 09:10 AM
krazyteg
Suspension & Brakes
45
Jun 6, 2007 04:11 AM
cheesebox
Jun 28, 2006 07:27 PM
Creep
Dec 16, 2003 09:40 AM
