Suspension & Brakes Theory, alignment, spring rates....
2000 H22 Civic Brake upgrade
Old Jan 2, 2011 | 01:55 PM
Woody.'s Avatar
Default 2000 H22 Civic Brake upgrade
I'm looking to do an oem brake upgrade. My car will be swapped with an h22.
Whats the best upgrade I can do for the front and rear at the most cost effective price.
Old Jan 3, 2011 | 09:22 AM
KdF's Avatar
KdF
Default Re: 2000 H22 Civic Brake upgrade
Search.
Old Jan 3, 2011 | 10:34 AM
unusual71's Avatar
no one searches?
Old Jan 3, 2011 | 06:12 PM
KdF's Avatar
KdF
^^ Lol.
Old Jan 4, 2011 | 07:31 AM
Libertariat's Avatar
Ek Forever y0!
Dynalite wilwoods can be had for about $600.
Front integra brakes with brembo blanks and hp+ pads will probably be more than enough braking power for you though. What ties are you running?
Old Jan 5, 2011 | 10:07 AM
Woody.'s Avatar
Getting new tires soon.
205/50/15 Yokohama S drives.
Old Jan 5, 2011 | 01:06 PM
Ek Forever y0!
Yokohama S. Drives are very solid summer tires.
As far as "OEM" upgrades that depends on the trim of your car.
Ex/si knuckles can accommodate ITR calipers with perhaps a bit of modification.
Your car isn't necessarily going to need more stopping power because of added weight or added power. Your car will still weigh about the same and I doubt you'll be doing 150mph.
Good pads and fresh fluid should be more than enough for your needs. Especially if you've got an EX civic with rear discs.
If you look at the brake FAQ or the stickies there are plenty of links to "OEM" brake upgrades.
Old Jan 5, 2011 | 05:25 PM
Woody.'s Avatar
I read the FAQ but I dont wanna go 5 lug.
So I guess i should just get aftermarket Dynalites?
Theyd run be about the same price as aquiring all the oem parts
Old Jan 5, 2011 | 05:38 PM
Ek Forever y0!
You don't have to go 5lug to use ITR calipers.
http://www.b20vtec.com/forums/suspen...pplicable.html
There's a solid compliation of OEM brake upgrades. It's a good read.
Old Jan 6, 2011 | 04:48 PM
Woody.'s Avatar
Will the bigger front rotors and calibers clear 15" wheels?
Old Jan 6, 2011 | 04:50 PM
Ek Forever y0!
That's dependent on the rotors, wheel manufacturer, and wheel offset.
Usually some hub centric spacers can solve that issue.
Old Jan 6, 2011 | 05:56 PM
Woody.'s Avatar
Id plan on getting brembo blanks
And OEM em1 si wheels.
Old Jan 6, 2011 | 05:58 PM
Ek Forever y0!
No OEM wheels are going to fair well at clearing larger calipers. Again, define larger.
em1 brakes and integra brakes are going to be slightly larger. They'll clear 15" rotors.
NSX calipers, S2000 calipers, etc will likely need a 16" wheel or some solid aftermarket 15" like RPF1, volk, etc.
Old Jan 7, 2011 | 07:07 AM
Woody.'s Avatar
I was planning on running the Itr caliper. 11.2 rotor.
Old Jan 17, 2011 | 06:33 PM
Woody.'s Avatar
Also looking at the BFG G Force tire.
Sufadev
16
Dec 26, 2014 09:49 AM
turbo_d16
Jun 3, 2007 07:51 AM
jsol
Honda Civic (2001 - 2005)
14
Mar 19, 2006 03:49 AM
CooBlueDAB
May 2, 2004 09:29 AM
EK-Cruiser
Aug 30, 2001 10:42 AM
