t3 t67ho?
Old Jan 1, 2011 | 05:31 PM
runsfromdacops's Avatar
Default t3 t67ho?
i have already tryed the search button/google and cant find ****.
i am trying to find out what size the ex. wheel is on the ho. si that i can figure out what ex houseing i can swap it with.i know its a p-trim but that does not help a whole lot
thanks HT
-alex
Old Jan 1, 2011 | 08:18 PM
TheShodan's Avatar
Moderator
Default Re: t3 t67ho?
The turbine wheel is a standard P-trim 2.944" wheel diameter for the T3/T67. "H.O.", just means that the turbine housing has been slightly modified for supposedlyslightly better exhaust energy dissipation. but nothing physical has changed.
Old Jan 1, 2011 | 08:38 PM
forgive my noobnes but im trying to learn.
per rull races web site.
the standered t3.t67 has a stage 5 ex wheel. while the ho has a p-trim ex wheel.
but if i read your reply right, the ex wheel is actuly the same and the ex. houseing its self is the only difernce.
so if i want to put a bigger .82 houseing on my curent turbo i need a HO specific .82 housing. right?
Old Jan 2, 2011 | 04:51 PM
up for more info
Old Jan 2, 2011 | 05:40 PM
TheShodan's Avatar
Moderator
The stage 5 and P-trim wheels are completely different, and the housings are not interchangeable. I've rarely seen a T67 in a stage 5, but whatever, its not a "standard turbo" anyway. So, if you have a P-trim wheel, then swap housings. If you have a stage 5 wheel, you won't be able to do it. Measure your wheel (Stage 5 = 2.7445", P-trim = 2.944"
Rus1an
Feb 27, 2016 08:30 AM
runsfromdacops
Feb 2, 2011 09:19 PM
BoostedD15B7
May 15, 2003 07:19 AM
