Built GSR Block
SOLD TO A GOOD BUYER!....TRACTION ISSUEZ
Have receipt to prove it...done in 8-27-2010
B18C1
short block
bore and hone
surface block
hot tank block
grind crank
balance crankshaft
pin fit-wrist pin end of rods and pistons
align hone block-with ARP studs
R&R pistons and align
Not sleeved
81.5mm bore CP 9.0:1 pistons
Eagle Rods w/ARP bolts-ARP 2000
Rear main seal-BS40430
Pan gasket-felpro molded rubber pan gasket
Rod bearing set-CB1275H-.25
ACL main bearings-5M1959H-.25
ITR oil pump
OEM oil pump pick up
GSR pulley
Only 1000 miles....dynoed at 550 hp on C16.
Parted out the motor. This setup is well over $2500
Asking $1400 obo. I'm willing to trade for some EG/EK parts. Tell me what you have. Depening on your trade you might have to add some cash.
mainly looking for....full coilover suspension for EK/EG, CTR cluster for EK, good name brand wheels w/tires (on 15" or 16")
For faster response...916-613-1343 (call or text)
What you see is what you get.
B18C1
short block
bore and hone
surface block
hot tank block
grind crank
balance crankshaft
Not sleeved
ITR oil pump
GSR pulley
to 450hp on pump gas.
I have the receipt when the block was built (8-27-10)
thanks...
effanatic91
Northeast (Sales)
Jul 4, 2010 07:41 AM
DragInteg
Nov 19, 2004 07:02 PM
