Transmission & Drivetrain Gearboxes, Differentials, Clutches
Cable trans into EG
Old Jan 1, 2011 | 03:25 PM
f@sth@tch89's Avatar
Default Cable trans into EG
Is it worth it? is there a downside to doing it?
I have a b16 with cable trans(s1) and was wondering if i should just get the hasport mount kit for cable tranny in eg or just get a hydro tranny.
a possible problem is i already have an ACT clutch kit from my last build(b20vtec w/ cable trans) and dont know if it will work on a hydro tranny and i dont want to buy another clutch kit.
any suggestions. im looking for a hydro now.....
Old Jan 20, 2011 | 06:33 AM
Scorchin Civic's Avatar
Default Re: Cable trans into EG
Don't totally rely on this but if your cable transmission was a 1992-1993 then I do believe that you can use the clutch items with a hydro transmission.
As keeping your cable transmission and placing it in your eg, I had a friend do it and it seamed to work fine for him. However, we all should know that cable transmissions are older so have way more miles on them. I would suggest you sell the cable and find a hydro B16 transmission.
Just my $0.02 so use it wisely!
Old Jan 20, 2011 | 12:12 PM
sleepencivic's Avatar
I have a y1 in my eg hatch no problems here..there are two different clutches for these cable transmissions..
Old Jan 21, 2011 | 05:17 PM
94EG8's Avatar
Seagull Management
Personally I don't think it's worth it, you need to buy a hydro to cable kit (which rarely seems to work right and not cause clutch engagement issues) and you've still got a crappy cable tranny. My advice? Sell the cable tranny to someone with an EF/DA and buy a hydro tranny.
Old Jan 25, 2011 | 07:25 AM
Mindgamez's Avatar
The s1 Trans are small spline, so you will have to use a 92-up clutch. And no its not worth it, it would just be easier to get a 92-93 GSR trans and a new clutch than converting to hydro,
Old Jan 25, 2011 | 08:10 AM
94EG8's Avatar
Seagull Management
No. They are small spline, but small spline uses a '90 - '91 Integra clutch.
Also, the OP has an EG, the car is already hydro.
Civic89stdB16
Feb 6, 2011 03:59 PM
egb16pg
Jan 21, 2007 10:38 AM
