Honda / Acura Parts - Turbo Partout, S2000, Blox, ETC
trying to clear out some stuff i no longer have need for.
* Spoolin Performance Turbo Kit (Complete) - $1400 (willing to part out)
- Spoolin Log Manifold w/ 3" Flex DP & Dump tube (B-Series A/C P/S Compatible) - $400
- Custom Intercooler Piping Kit - $175 (includes T-Bolt Clamps, Silicone Couplers, and reducers)
- XTD Racing Intercooler - $140 (hides most apps w/o cutting grille, minor damage, WORKS)
- 38mm Tial Wastegate w/ Variety of Springs - $175
- Greddy Type RS Blow Off Valve - $175
- Venom Performance 550cc Injectors - $200 (cleaned and flow tested, no resistors needed)
- Apexi Auto Turbo Timer - $60
- Greddy Electronic Pressure Gauge - $110 (52mm white face)
- Greddy Electronic Pressure Gauge - $100 (52mm black face)
- Greddy Electronic Boost Gauge - $120 (52mm white face)
- Greddy Air Fuel Ratio Gauge w/ o2 Sensor - $150 (60mm white face)
- ALL Greddy Gauges - $400 (will toss in universal pods)
- OBD1 P28 Chipped on CROME by Ryan @ Tech 3 - $150 (PM Type R 7PSI 550cc)
- P72 GSR Oil Pan Tapped for Turbo Return - $60 (minor dents, no leaks)
- ATP Turbo Oil Feed and Return Lines - $75
- Blox Racing Oil Filter Sandwich Adapter - $25 (black)
- Blox Racing Vacuum Manifold - $25 (black)
- Garrett 50 Trim t3/t4 hybrid turbo - $350 (possibly need new seals, no shaft play)
- Garrett T3 Turbo - $150 (needs rebuild, shaft and seals)
- Spoolin Performance Intercooler - $170(like new)
- Universal Triple Pillar Pod - $15 (brand new)
- Del Sol Triple Pillar Pod - $10 (used)
*17" JDM SSR Hasemi Proto-S Wheels w/ tires - $800
-17x7.5 5x114 32+offset 215/45/17 Yokohama Tires (50%)
-17x8 5x114 38+offset 245/45/17 Nexen / Riken Tires (50%)
*Blox Racing Gold Extended Lugnuts - $40 (16pcs, used)
*Blox Racing Gold 490 Spherical Shift **** - $35 (machined gold)
*Ricks Voodoo Pearl Shiftknob - $40 (used)
*Greddy Aluminum Cooling Plate for 00-08 Honda S2000 - $50
*Benen Orginal Tow hooks - $60 (machined silver, pair, before it was bought out)
*Mugen Sport Pedals - $50 (Brand New in Mugen Packaging w/ part #)
*JDM CL7 Acura TSX / EuroR Rear Window Visor w/ hardware - $75
*4x100 Type R Front Big Brake Kit for Civic / Integra - $275
-Redrilled Type R Rotors to 4x100 (5k used)
-Rcrew Racing 3mm Spacers
-Type R Calipers w/ 25t brackets
-3 Sets of usable Street / Race Pads (90%, 50%, 30%)
* Pioneer Avic N1 Single Din Navigation - $350
-Refurbished, new ribbon, cd mech, cooler fan
-Complete w/ map disk
-brain & all cables included
*ASpec Racing JDM EJ8 License Plate - $20
*Vision Technia CF B-Series Spark Plug Cover - $50
*99-00 EM1 Civic Si Amber Climate Control Switches - $40 (no bezel)
*VIS Racing V-Spec Front Coilover Sleeves for Civic / Integra - $40 (pair)
*92-95 EG USDM Del Sol Vtec B-Series Intake (complete) - $50
*96-00 EK USDM D-Series Intake (complete) - $40
*99-00 EK Mugen Carbon Fiber Lip - $50 (cracked but reinforced)
*Brembo Red Caliper Covers - $35 (new)
*Spoon Sports Caliper Covers - $50 (new)
*EG / DC Stanley Side Markers w/ bulbs - $25 (brand new, no pigtails)
*Blox Racing Vtec Solenoid Cover - $13 Large (brand new)
Willing to trade for:
Aftermarket CAMs for F20c S2000
68mm Throttle Body
S2000 Coilover Kits (sleeves are ok also)
AP2 S2000 Headlights
AP2 S2000 Cluster
S2000 CF Spark Plug Cover
68mm Throttle Body
AP2 S2000 Cluster
FurY
Aug 8, 2005 06:04 PM
E-spec Tuner
Sep 17, 2003 06:29 AM
