Loose steering
Old Dec 30, 2010 | 08:15 PM
mkrieger500's Avatar
Default Loose steering
Hello everyone! I have a 1993 accord ex with 194,000 miles on it. Recently I noticed I have some play in my steering wheel and some odd vibration going 40mph. It only has play when I jerk the wheel to the left. I can move/turn it about 1 or 2 inches where as when i jerk it to the right i have very little. I recently did the front strut/spring assemblies and stabilizer bar bushings... It also is VERY sloppy while driving at higher speeds. Could it be a CV joint or rack and pinion?? Any help is very appreciated!!!!!
Old Dec 30, 2010 | 11:31 PM
nus_dogg's Avatar
Default Re: Loose steering
I would inspect the rack-N-pinion for any loose bolts. I'd also check where the steering columns bolts to the rack-N-pinion at the bottom of the pedals in case the pinch bolt backs out or something.
Old Dec 31, 2010 | 02:33 AM
Balwin's Avatar
Check the tie rods. The boots always fail on accords.
Old Dec 31, 2010 | 02:03 PM
Sounds good thanks guys. I am also going to check the driver side sway bar bashing too because now that I remember that one seemed funny when I put it on. Like it didn't look right so it could be messed up too...
Old Dec 31, 2010 | 07:00 PM
nus_dogg's Avatar
The Tie-Rod boots are called Power Steering Bellow's Boot just in case you're curious what to call them.
ahburner
Honda Civic (2001 - 2005)
Sep 7, 2016 06:53 PM
r22thomas
11
Aug 10, 2011 12:24 PM
Freeltec
Aug 29, 2005 07:24 PM
litterbox
33
May 26, 2005 07:53 AM
jabroni95gsr
Feb 13, 2003 04:12 AM
