Question about Si Cluster.
Old Dec 30, 2010 | 08:09 PM
Bertamus's Avatar
Default Question about Si Cluster.
The PO installed a Rex dash in my Si Hatch, which I have to remove and put the stock Si Hatch one back in. So my question is are the clusters the same between the two? CRX Si and Hatch Si?? Thanks
Old Dec 31, 2010 | 09:02 AM
ef9betterb's Avatar
Default Re: Question about Si Cluster.
just about the same all of the mounting points like that hold the dash in... the crx and hatch shifter and radio cluster are diffrent the hatches are strate while the crx's slightly turns twords you and it has an diffrent posisioning of the ac switches so ull have to change the metal holder that holds your radio and ac controls... alll of this is correct unless the po mocked it up and tryed to make it fit w/o changeing the shifter cover, like were the shift boot is
Old Dec 31, 2010 | 10:05 AM
Bertamus's Avatar
I'm not concerned about the dash, I already know about the console, and controls(Mine still has Hatch HVAC controls) My question is about the gauge cluster. Thanks
Old Dec 31, 2010 | 11:54 AM
ef9betterb's Avatar
they are identical, were they mount up at and they both have the cable speedos and their plug and play atleast the ones i have
Choy
May 9, 2010 05:10 PM
funkified
25
Nov 30, 2006 09:08 PM
Gen4Si
Jan 30, 2005 03:38 PM
w00dy82
Nov 27, 2001 04:43 AM
