reuse oem bearings with rebuild?
Old Dec 30, 2010 | 11:47 AM
bnmm's Avatar
Default reuse oem bearings with rebuild?
im gonna be doin a z6 eagle vitara build. i read and read and everyone rant and raves about acl and oem. i understand u can get oem bearing to fit exact but acl king etc is a one size fits all. my question is could a just reuse the main and rod bearings i take out if its coming from a low mile engine vs 190xxx mile engine vs just buying kings and hope no clearence issues. (with eagle rods)
also anyone know where i can a single vitara? THANKS!
Old Dec 30, 2010 | 11:48 AM
bnmm's Avatar
Default Re: reuse oem bearings with rebuild?
kinda budget biuld lol
Old Dec 30, 2010 | 02:14 PM
Natural Aspirations's Avatar
The eagle rods will not have the same clearances as your OEM rods so even if it was a good idea it wouldn't work out quite like you think.
Old Dec 30, 2010 | 02:51 PM
CO_RaceFab's Avatar
I use standard size kings/tip lines/acl with eagle rods on a bunch of engines and the ckearances are always in check
Old Dec 30, 2010 | 02:59 PM
bnmm's Avatar
now the question is KINGS or ACL
Old Jan 1, 2011 | 03:28 PM
TEAM ASSASSIN SI's Avatar
don't cheap out bro you will regreted later i personally use acl race bearings.
Old Jan 1, 2011 | 05:54 PM
Mugencrxsir1's Avatar
ACL all of the way!
Old Jan 1, 2011 | 06:03 PM
sanman000719's Avatar
i agree get new and you will be alot better off
Old Jan 1, 2011 | 10:11 PM
blwn95civic's Avatar
IMO oem Honda bearings are hard to beat. I've used them on all three of my motor builds, current setup is even running two different size main bearings.
* Edit * I just noticed the title said reuse.. I would never reuse any bearings with a motor build.
Old Jan 2, 2011 | 07:27 AM
blackeg's Avatar
yep, i agree with all of this.
now to my understanding the eagle rods are sized to match the green bearings, but you still have to combine that with the crank markings, you could easily wind up one or 2 colors on either side of green. best best way to do it is to mic everything out, find out the difference between crank and journal size, divide that by 2 and find the oem bearing that fits that size with a difference of like .0015 or so to account for tolerences
Old Jan 4, 2011 | 12:08 PM
91-lsvtecsi's Avatar
Rumor is that King makes ACL bearings? But on topic! Dont reuse ur bearings!
Old Jan 4, 2011 | 10:30 PM
CO_RaceFab's Avatar
^^ they do... **** is all the same
Old Jan 9, 2011 | 07:46 PM
bnmm's Avatar
just an idea i thought of haha
Old Jan 9, 2011 | 07:48 PM
Schister66's Avatar
Man U FTW
I wouldnt re-use bearings under any circumstance. If the clearances are off, you'll either have metal-on-metal contact which will eat the bearing or you'll have low oil pressure if the clearances are too loose. If you must re-use, check carefully with Plastigauge to be sure you're within spec...
Old Jan 9, 2011 | 08:32 PM
ShopClosetSOHC's Avatar
I dunno if king makes acl but i always use king, never had a problem
cibao2ner
Jul 21, 2010 12:35 PM
b20vtech
Feb 21, 2006 07:57 PM
- Sim -
Dec 29, 2004 11:43 PM
itralex
Sep 11, 2004 03:16 AM
itralex
Sep 10, 2004 06:12 PM
