Will code 6 make my car shut off??
Old Dec 30, 2010 | 09:51 AM
rudyndrew's Avatar
Default Will code 6 make my car shut off??
I just took care of my my code 4 by changing my dizzy, but my cars still shutting off while driving. Its been doing this since i put the si trans on & i accidently ripped my engine coolant temp sensor, but i went to the junkyard & got another 1 & still my gauge wont go up when the engines warmed up. So will it cause my car to shut down is my question? Any help please?? This didnt happen before.
Old Dec 30, 2010 | 12:30 PM
D16SiHatch's Avatar
Default Re: Will code 6 make my car shut off??
i dont believe the ect code will cause the engine to die, but i could be wrong. there are 3 ect sensors/switches though. one on the back of the block that kicks on the radiator fan. a 2 prong sensor on the side of the head that provides the ecu with info, and will cause the ect code if their is an issue. and lastly the 1 prong 1 wire sensor is for the cluster reading and it will not throw a code if it's not working.
Old Dec 30, 2010 | 02:12 PM
CRX_RR's Avatar
i replace the TW sensor and it was all good.
coffin on wheels
Feb 22, 2007 11:22 AM
REDREXMANB16
Nov 23, 2006 09:54 PM
kizner
Jan 29, 2006 09:39 AM
UNDER PRESSURE
Feb 4, 2003 01:07 PM
