P8R head... What pistons??
Acquired a P8R head for my turbo non-vtec build. As you may know, P8R utilizes a larger VTEC sized valve than other non-vtec heads. So this poses a problem when ordering forged pistons for my build(due to valve reliefs needing to be larger than normal non-vtec forged pistons). Block is going to be sleeved and bored to 84mm. Do I just get 84mm pistons for a VTEC engine? Will there be any problem putting these pistons on LS Eagle rods?
Thanks H-T!
Thanks H-T!
http://www.jepistons.com/Catalogs/SR.../b20_b16a.aspx
the JE SRP pistons for the B20 with the b16 head are designed for 33mm valves (as the b16 head has 33mm valves), its what im gona be going with
haas480
Jul 27, 2009 10:15 AM
Prototype115
Honda Civic (2006 - 2015)
13
Sep 29, 2007 10:35 AM
knoj
Sep 30, 2004 07:39 PM
