dire need of help or ideas...
Hello. I have a 92 accord automatic. The main pulley/crank pulley/harmonic balance came loose,the car ,of coarse died. I jumped it and got it home w/no problems, removed the tire to look at what had happened and found that the pulley key pin had twisted slightly and the bolt had come loose.I removed the bolt and the pulley then removed the key to see if the hub key hole slot was twisted, and found it to be ok.I found i will need a new pulley and key, and probably a new bolt also. I also started the car to get it um on and off ramps and it started a ran jus fine. After doing all of the above, I put the tire back on and went to start the car and it wouldn't start. I did not have the pulley or key in, cuz i was just moving it in to the garage, I tried several times and it acted like it wasn't getting fuel, no huffs and puffs, or sputters or any other strange noises,clanks or bangs. It jus wont start, so I put the key back in it s position and tried again, nothing. Does not flash any codes, and i disconnected the battery to see if some thing would reset, still nothing... Does anyone have any Ideas, I really need some help on this, could I have done some thing to the timing ??? Please help... Thankyou...Dave
i have a 91 ef hatch D15 just shut off on me wile driving. long story short had bent valves timing belt did NOT brake just jumped time. k so i get a used head. put it on and yes i have lined up the timing marks made sure its not 180 out.new timing belt i have fuel i have spark. crank no start however when i crank it it backfires out the exhaust i need some ideas im out
driveslow
Apr 17, 2009 11:30 AM
civic_tuned
Nov 29, 2005 08:01 AM
