were your black ecu plugs(B+C) numbered like this? 90' si hatch
on my black plugs there are numbers for each wire there are two rows of wires correct? these wires are numbered.one row has numbers 1-11 the other row on the other side of the plug has numbers 12-22 these numbers are on the black plugs only.was your plugs numbered like this?
i want to wire up my swap but am getting mixed replys on which pin is which.thanks in advance. 90' si hatch b16a
Try http://www.dmoore.com click on DX/STD to ZC wiring he has an awesome download of the pin reference.
i found that it depends what reference you are using, import tuner and scc had articles about the dpfi-mpfi wiring, and they used different pin numbers, although both of them yeild the same result, just stick to one then it should come out right
