What O.D pipe/tube best to match up to a t4 turbo inlet flange
Old Dec 29, 2010 | 02:05 PM
wade's Avatar
Default What O.D pipe/tube best to match up to a t4 turbo inlet flange
Making a turbo kit unlike any I have before. I have a t4 based turbo. Going to feed a single sch40 pipe to it. What OD is best? I see the t4 inlet flange dimensions are 1.98" X 2.98". So would a 2.5" OD pipe be best after I crush/form it to fit the rectangular flange?
Thanks
_wade
Old Dec 29, 2010 | 03:06 PM
Mr.Spec's Avatar
Default Re: What O.D pipe/tube best to match up to a t4 turbo inlet flange
2.25 id pipe pretty much a 2.5 od
Old Dec 29, 2010 | 06:42 PM
5thgen's Avatar
If you are going sch40 I would use 3".
I used 3"OD .065 wall on a t4 flange and it came to be pretty close to the flange cutout. The tube was a little bit bigger than the cutout still. With sch40 you should be really close I would think.
I measured the flange opening as well just to be sure, and it is a little under 2" x 3".
Pics are off of a phone.....I don't have a good camera. You should be able to make out most of it.
kevinwarren240
Welding / Fabrication
Aug 23, 2009 05:44 AM
hondaeg8
Feb 6, 2004 09:50 PM
redboost10
Nov 30, 2003 08:45 PM
BoostedH23a1
Apr 26, 2003 12:00 AM
Andrew 825SM
Jun 20, 2002 11:59 PM
