downpipe flange
Old Dec 29, 2010 | 09:41 AM
that-guy's Avatar
Default downpipe flange
looking into buying a turbo sometime in the near future and am stuck on what i want to do for the exhaust side. i want a 3" downpipe as well as V-Band, however i cannot get a 3" V-Band with T3 housing. so my question is, should i just get the 2.5" V-Band and use a 2.5-3" transition, get a 4 bolt-3" V-Band adapter, or just stick with 4 bolt?
Old Dec 29, 2010 | 10:03 AM
91jdmhatchback's Avatar
Default Re: downpipe flange
A 3" tube will fit on a standard t3 4 bolt downpipe flange. But if your dead set on a v band (which i find unnecessary as you rarely take off the downpipe anyways) you could always get a modified atp turbo turbine housing or have your modified to fit a 2.5" v band and then do the transition to 3" after the housing.
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
champLSinteg's Avatar
Just get the vband adapter or have someone weld a vband flange directly to the housing. I am using the vband adapter.
Old Dec 29, 2010 | 10:15 AM
I think those adapters look tacky. It's not much more money to have it machined.
huepowered
Welding / Fabrication
Jun 8, 2006 04:22 AM
nathanie1
Sep 17, 2005 09:39 PM
jason190
Apr 1, 2005 12:29 PM
redboost10
Nov 30, 2003 08:45 PM
Acura_I-RS
Mar 29, 2003 07:31 AM
